what's that sound
08.05.2020 16:47 # 1
erdi777
mrb friends I have a problem in my car. After 60 km, it feels like I get out of the wheels and die. Do you think I should replace the front set completely? or if I just change the balls? How much do the balls cost?
08.05.2020 16:47 # 2
toGah
Go to a tie-rod balancer, take 10-15 TL. he tells you what's going on
08.05.2020 16:47 # 3
erdi777
I don't think you will make a sound from the rot ....
08.05.2020 16:47 # 4
Does it disappear when the brake is applied?
08.05.2020 16:47 # 5
falan
There was such a thing in me. I don't know the name exactly in the rear wheel & nbsp; there was an iron master clenched her boredom improved ... & nbsp; It's best to have the rotter look at it to learn exactly.
08.05.2020 16:47 # 6
erdi777
It doesn't matter if it brakes. Only when it goes below 60, the sound stops.
08.05.2020 16:47 # 7
leony510
bearings are blown
08.05.2020 16:47 # 8
aclern
[QUOTE = koliva] Does the sound disappear when the brake is applied? [/ QUOTE]
I have the same incident, but it doesn't matter 50-60, and when the brake presses, it sounds loud.
08.05.2020 16:47 # 9
[QUOTE = aclern] [QUOTE = coliva] Does it disappear in the sound when the brake is applied? [/ QUOTE]
I have the same event, but it does not matter 50-60 and there is no sound when the brake is pressed.
If the sound disappears when the brake is applied, it is probably caused by brake pads. Often the problem is solved by applying virgin grease to the back of the brake pads. To insert the most beautiful system and clean it nicely and put it in place with its virgin grease. Reviews
08.05.2020 16:47 # 10
metin
That sound is caused by the brake pads rubbing against the brake disc. The linings or discs may be worn irregularly.
In addition to the idea that the coach says, there may also be a lining spray.
08.05.2020 16:47 # 11
impertore
Check tires & nbsp; stone chips entered the tire.
08.05.2020 16:47 # 12
erdi777
Solved: D: The nut holding the valve in one of the tires has fallen into one of the tires. It made a sound. I had it removed. No problem for now: D cvp weren thanks to everyone
08.05.2020 16:47 # 13
metin
[QUOTE = erdi777] solved: D: D the nut holding the valve in one of the tires has fallen into that sound. I would have made it. No problem for now: D cvp weren thanks to everyone [/ QUOTE]
What is interesting is that ((& & nbsp;
once in our old vehicle, we found it difficult to find the sheet behind the pad used to balance the tire there & nbsp; "Big
