What oil to the steering fluid?
08.05.2020 19:37 # 1
pocker19
Hello friends,
Yesterday we checked the steering hydraulics while making engine oil changes, which went down to the "min" level in its own bar. I will change the steering fluid depleted oil, but I don't know which oil. Some talk about a red oil, others talk about atf oils. What is the most suitable oil for the 307's steering fluid? In addition, although the steering is electrically assisted, it feels very stiff. Does oil loss cause the steering to be stiff?
08.05.2020 19:37 # 2
aktivist
OIL DESTRUCTION hardens and clicks the steering wheel. For this, the color recommended by the Peugeot user manual and I was satisfied (I put it 3 days ago) is red. the price was 18.50 in total oil.
08.05.2020 19:37 # 3
fætih
it works according to my pump head. I talked to the revising places today. There was no whirling tinker repair that they called the upper pump. they talked about a special oil that cut her voice.
I think if you are going to change it, investigate that oil ...
08.05.2020 19:37 # 4
pocker19
[QUOTE = activist] OIL DISSOLVATION hardens and clicks the steering wheel. For this, the color recommended by the Peugeot user manual is also red (I put it 3 days ago) is red. cut out instantly;) easy price was 18.50 in total oil [/ QUOTE]
Thank you very much for your attention. Did you get the oil inside and the hose when you put the oil?
? Or would we add a bit on the pole?
pocker19 2016-01-27 03:26:58
08.05.2020 19:37 # 5
bb-mahmut
Dissection hydraulic oil is used, if the price of 10 tl, my friend, if the hardening is hardened, the oil is reduced. Also, if the sound comes from the decreasing oil, if the sound is cir cir oter.
