What kind of vehicle is 307? |
| 08.05.2020 14:08 | # 1 |
Besides, is there a special, honorable service and master of your job that you would recommend in maslak?
| 08.05.2020 14:08 | # 2 |
It will satisfy you in the diesel class because of its 110-meter diesel performance. On the other hand, if chıp application or something comes in, it will be a platform .. You can get 140-150 hp from the vehicle .. I do not encounter any problems, I use the same tool on me, I get on the car at least 5 minutes at 307. You need to wear cm because it is a pretty stork with the original :) You can end the heat with a nice knife rim .. May it be better |
| 08.05.2020 14:08 | # 3 |
Is it a good clicker tool in general (I have some click obsessions)? Other general problems encountered in the 307s? Yeah, it's an extreme vehicle. Doesn't it matter if it's 3.5 cm high or too hard on 5?
| 08.05.2020 14:08 | # 4 |
Let me comment as someone who has used 307 and just sold it. 1.6 110 and Dizel will please you in terms of performance, I tried. I liked it. (Mine is 1.4 70 hdi di there.) In general, there may be problems with the Cam control key, Com2000, and 5 Cd Changer in Horn, but of course you are in luck. These are the problems I came across as a result of my research. I mean, we cannot say that they are all available Maybe the suspensions are stiff may bother you, but I was satisfied. Of course, this is a matter of taste. I think the choice of springs and wheels should be done well since it is a bit high. When you choose these beautiful, you will become a monster. I hope you will be satisfied using it.
| 08.05.2020 14:08 | # 5 |
May Allah give it to your heart. Since I use 206, I cannot comment on the 307, but in general I can say that it looks a little bit of use. If you take care of your vehicle, pay attention to the bump pit logar cobblestones, if you use them without tiring, you will not see anything in the click event.
| 08.05.2020 14:08 | # 6 |
endorphine |
I have a 2006 307 comfort auto about a week ago. I took gears. A tool that would be more than enough for me unless it broke down. It has a spacious interior. This is the feature I like the most.
| 08.05.2020 14:08 | # 7 |
I have a 307 2005 model 1.6 hdi look 110 hp I have a service registered at 82000 km, I bought it 3 months ago, 160 km in the city 90 lra out of the city burns out, so 5.6 liter in the city 3.1 liter out of the computer computer, except for the rear shock absorber hardness, so nice car 2004 307 no problem. After 2005, electrical components were used, 407 masts are used. 110 hp asphalt is digging on the highway. I enter 90 to the steep ramp. I go up to 160. If the car mechanic is nice, buy it immediately.
| 08.05.2020 14:08 | # 8 |
shamed |
Ultimately, the more meticulous we care about the use of the person, the better the vehicle will be. |
| 08.05.2020 14:08 | # 9 |
When you drop the car, the comfort goes a little. Clicks start in the vehicle. It would be nice in appearance, but some comfort should be compromised. |
| 08.05.2020 14:08 | # 10 |
tskler for answers ... music system, especially the columns are weak in bass. again, especially the ones on the back give a burst effect with some bass use. Does anyone have any comments on music systems and what needs to be done for improvement? and in general, do you prefer the official service or private? is there any honest trades you can recommend in maslak?
| 08.05.2020 14:08 | # 11 |
service is always more guaranteed, but if you find a good master, of course, it will be both convenient and comfortable. If I do not remember the place of maslak, our sponsor and efe are wrong :) You can make changes such as water in the music system, firstly, you can take a strong sound with the pioneer or sony sound output, and you can heat up with 1 set midi bass set small blade amp. If you do not want subwofeer, these will be enough .. max cost will be between 250-300 TL |
| 08.05.2020 14:08 | # 12 |
[QUOTE = EmRaH] service is always more guaranteed, but if you find a good master, of course it will be both convenient and comfortable for you. You can make changes such as water in the music system, firstly, you can take a strong sound with the pioneer or sony sound output, and you can heat up with 1 set midi bass set small blade amp. If you do not want subwofeer, these will be enough .. max cost will be between 250-300 TL [/ QUOTE] Will Emrah save both tape and a set of mid bass to 250-300? For now, I prefer to be in search of a solution without touching the tape. as I said in the previous email Especially the posterior bass has very bad resonance. is it from columns or the structure of the door?
| 08.05.2020 14:08 | # 13 |
If you take the bass, you will have to get the tape and the amp. If you change the tape, you will get 4 normal 16 cm oval columns without changing the tape. but you can spend 100 TL and buy and install 4 sets of columns. |
| 08.05.2020 14:08 | # 14 |
neither my brother nor the music system, the parts of this car start from escaping, a flywheel set 1500 tl injector pump 3000 tl en ....... piece 500 tl you put it to the music system pıoner set with albi facility plumbing okay here it is 307 lower beside the conversation bakya bakya ....... |
| 08.05.2020 14:08 | # 15 |
fatih1903 |
[QUOTE = polatkaptan] ya brother what music system do you start with this car parts escaping from a whirlwind set a flywheel set 1500 tl injector pump 3000 tl en ...... piece 500 tl you put it on the music system pinier born falcon with albi facility okay here it is 307 sub Have a conversation beside him ....... [/ QUOTE] : / |
| 08.05.2020 14:08 | # 16 |
I am also a 307 1.6 hdi comfort user about 1 month. I have read all the comments carefully. It is completely correct, our friends told their observations directly. Yes, it is an excellent vehicle if used carefully and gentle. According to this situation, my previous vehicle was 2000 model passat. Therefore, according to the passager, it gets the sound too much. The power in gear is incredible. Driving is an excellent vehicle.
| 08.05.2020 14:08 | # 17 |
[QUOTE = polatkaptan] ya brother what music system do you have parts of this car starting from escaping you know a flywheel set 1500 tl injector pump 3000 tl en ....... piece 500 tl you put it on music system born falcon with albi plant ping okay here is 307 He has overcook the conversation beside ....... [/ QUOTE] everybody wants to do something on their own car, nobody can mix it :) everyone does not harm the vehicle without touching the vehicle's installation, without damaging the vehicle.
