What kind of problem is this?
08.05.2020 14:02 # 1
friends I am Mehmet from Istanbul
I will have time to introduce myself, but I would like you to help me with my first message.
my car 1.6 307 auto-lpg li
When I put gas on my vehicle, it moves, I take my feet out of the gas, my hares run up to around 100. I took it to the center of the car.
I want to get your advice from you. What is the problem?
08.05.2020 14:02 # 2
Fatih
I live in a problem similar to yours nowadays. When I go out and press it, the temperature does not exceed 80. But when it gets slow and traffic goes between 90 and 100 ... I think there is a problem in the temperature sensor ... you can still help a friend from here. By the way, welcome .. Conqueror 2009-03-03 17:10:28
08.05.2020 14:02 # 3
HakanGokdemir
Welcome to us, I have no idea that an interesting breakdown is sure, but friends will help you, get well soon ...
08.05.2020 14:02 # 4
Thank you. Thank you.
I changed the thermostat, put 2 liters of antifreeze and took off the air, but it was not resolved: S
museless bedouin
MEHMET_CC 2009-03-03 17:27:55
08.05.2020 14:02 # 5
annoying..
08.05.2020 14:02 # 6
I'm waiting for help :)
08.05.2020 14:02 # 7
hasimayaz
I need to elaborate on the situation a little bit. I understand that while driving fast on this long road, your vehicle's temperature is in the 80's but the traffic idle is between 90 and 100, right?
If this is so, there is no wonder about this ?? This is so in every vehicle. The engine will inevitably stop at a lower temperature point, as better airflow is provided at high speed. but the only chance of cooling the vehicle is the fan motor. However, the fan provides less cooling in the face of strong wind. There are no separate thermostats for summer or winter in the original parts list of our vehicles. There are only a suitable thermostat to Turkey climatic conditions.
08.05.2020 14:02 # 8
Thank you for your hunger, my dear.
alone, my car is working normally, it hits red, my ipre stop warning lamp is blinking.
08.05.2020 14:02 # 9
hasimayaz
[QUOTE = MEHMET_CC] thank you for explanation, hasim bey.
Then the situation is different ... when the car gases, the water pressure increases and the water circulation relaxes. There may be two reasons for this, the first one is the circulation pump and the other is a blockage that may occur in the LPG system.
08.05.2020 14:02 # 10
I talked to a master yesterday that could be circulating, he said the same room :(
My lpg system is zero, I haven't bought any gas, I don't use it :)
My master did not understand myself, I will take it somewhere else, I am afraid I have not tried there before.
08.05.2020 14:02 # 11
hsnsnr
The fact that you have never used the lpg system does not change anything, there may be a problem in connection, and the recirculation seems more likely. I recommend that you have my circulation checked first.
08.05.2020 14:02 # 12
The circulation is heavier than the view of everyone :(
The bonnet once hurt does not hold any more :( :(
08.05.2020 14:02 # 13
hsnsnr
If you have the km maintenance done on time, it will not be a problem and you should buy more problem-free vehicles.
but they also have no technology
so comfort and distress
or 106 :)
08.05.2020 14:02 # 14
HakanGokdemir
This is of course a joke, the second hand is a bit of luck.
What was the mileage of my vehicle, hasn't it changed before?
08.05.2020 14:02 # 15
I guess it had never changed before because it was so worn out.
The maintenance of the vehicle at 110.000 thousand km has not been done properly, the side burst inside us :)
08.05.2020 14:02 # 16
HakanGokdemir
Brother at that time was not a mistake at 307, while all the vehicles with timing were 60,000 to 90,000 km, while heavy maintenance such as timing and circulation should be done, this is not something specific to peugeot, it is this way in all vehicles. Pray you didn't break the timing and bent your valves ...
08.05.2020 14:02 # 17
I bought the new car: (obviously when I did not look at it :(
I will not be on the scales after paying the money again, the stress and the time does not hold the engine yet.
My only wish is to sell it before I :)
08.05.2020 14:02 # 18
HakanGokdemir
Valla, I recommend you to take whatever vehicle is passing through, 106 beautiful and proven vehicle, above all, driving pleasure Clap But finding a cleaner in the market is harder than 307, find a good master, take it with him, give it to the master at least 50-100 what he will spend billions later. As you said, everything is not in money, once you get cold from the car it is very hard to warm it up ...
08.05.2020 14:02 # 19
HakanGokdemir
Mehmet, my brother, stop yaaaa, how much negativity this 307 is not as long as you are told ... put it in a good maintenance, well, the circulation has changed with the above triger. If you were unhappy, the timing break valves would have replaced the engine. So the worst thing has never happened, but ... hakan1203 2009-03-05 15:01:10
08.05.2020 14:02 # 20
hasimayaz
Whatever happens. If you are getting an unfamiliar vehicle you do not know. you need to add at least 500 - 600 YTL maintenance money to the price. 307 has no crime. As a result, parts such as timing set, circulation pump have a lifetime. This is so in every vehicle.
The vehicle has been overhauled, I hope for a long time, it will not cause any trouble
Page : / 2
