What is your advice?
08.05.2020 20:35 # 1
ibrahim
Hello friends.
I completed my car's tank today. It took 47.7 liters. However, the occupancy rate shows two teeth missing. I made a 50km road and continued to decrease. As if there were 2 teeth of gasoline at all.
Did anything happen to you? Is this going to be fixed or is there a repair situation?
08.05.2020 20:35 # 2
acabuco
[QUOTE = ibrahim] Hello guys.
Last day the car was low on gasoline, I threw 30 tl of gas, it did not go up, it remained in the same place, I drove for 15 minutes, then I went and threw another 30 tl of gas, again, the hand remained constant, then I threw 50 tl. This needle event is a bit strange in our 206 vehicles, in some such models in Renault brand vehicles. You shouldn't wear it.
08.05.2020 20:35 # 3
ibrahim
[QUOTE = acabuco] [QUOTE = ibrahim] Hello friends.
Last day the car was low on gasoline, I threw 30 tl of gas, it did not go up, it remained in the same place, I drove for 15 minutes, then I went and threw another 30 tl of gas, again, the hand remained constant, then I threw 50 tl. This needle event is a bit strange in our 206 vehicles, in some such models in Renault brand vehicles. You shouldn't worry. [/ QUOTE]
My first time was something like this. Is it permanent damage or temporary ..
08.05.2020 20:35 # 4
acabuco
[QUOTE = ibrahim] [QUOTE = acabuco] [QUOTE = ibrahim] Hello guys.
don't worry, don't worry, the samandira system can be changed, but even if this change happens in peugeot, unnecessary unnecessary expense. it won't hurt, so go ahead.
08.05.2020 20:35 # 5
If there is no problem in the operation of your vehicle, do not touch my brother. When you use it in low fuel for a long time, you can encounter such events. I think you have filled the tank to the brim at first it will fall like fast but then it will fall slowly.
08.05.2020 20:35 # 6
uzunca961
There is only one word to say about this event:
Wow pointer wow :)
If you use your vehicles for a long time, do not touch it. You'll get used to it over time
08.05.2020 20:35 # 7
tired06
Don't worry!
