What is water dripping from the exhaust? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 16:25 | # 1 |
altantezcan |
but mine doesn't drip like the tap you know? |
| 08.05.2020 16:25 | # 2 |
Canip |
I do it in mine, I check its water once in a while. There is no loss, it seems to be flowing from the tap because our exhausts are looking towards the ground, even if they are due to moisture in the air. I heard it from a master, as the exhaust in other vehicles was facing the face, the water accumulated in the exhaust, freezing in winter and causing trouble. |
| 08.05.2020 16:25 | # 3 |
As the exhaust gas is hot in cold weather, water accumulates and flows in the exhaust is quite normal.
| 08.05.2020 16:25 | # 4 |
Combustion equation reacts and exits. CO2 and H2O (water) are formed as a result of combustion of fuel. CxHy + (N2 + O2 + Vs.) + S + Pb - COMBUSTION - CO2 + H2O + N2 + (CO + NOx + HC + SO2 + Pb + PM) Fuel + Air + Additives Products with full combustion + Pollutant Exhaust Emissions (When combustion is not complete) As a result, oxygen (O2) in the air and hydrogen (H) atoms in the fuel react with combustion and form H2O (water). 06ÖZGÜR062011-12-05 00:50:20
| 08.05.2020 16:25 | # 5 |
Burning Hydrocarbon forms Carbon monoxide and water. If the fuel burns well, it is normal for water to form. If there is no water, it does not burn well.
| 08.05.2020 16:25 | # 6 |
djchaos |
When you get up in the morning, the top of the vehicle will be soaked as if it is raining. It is an event that comes from the cold. The water coming out of your exhaust is normal. There is no problem. & nbsp; |
| 08.05.2020 16:25 | # 7 |
mon |
[QUOTE = gravis_pro] Burning Hydrocarbon creates Carbon monoxide and water. If the fuel burns well, it is normal for water to form. Without water, it doesn't burn well. [/ QUOTE] this is the only correct comment. I congratulate our friend.
| 08.05.2020 16:25 | # 8 |
[QUOTE = gravis_pro] Burning Hydrocarbon creates Carbon monoxide and water. If the fuel burns well, it is normal for water to form. It means it does not burn well without water. [/ QUOTE] Pollutant emission that occurs when hydrocarbons do not burn well. > |
| 08.05.2020 16:25 | # 9 |
If water is dripping from the exhaust, how happy your car
