What is this System?
08.05.2020 16:27 # 1
Friends, I'll tell you about the 2 incidents I've had past, is this a system?
First, my car 307 2007 new chassis 1.6 HDI Comfort
I was on the last ramp and planted a lot + gravel and sand pit The ground wheel of the vehicle did not skid, the other did not pull, occasionally the other was pulling and I started taking off, while I was on the screen, he said, 1 light was on, but I could not see what was on, the car gave a warning when the skid was interrupted and it was cut off. What is this?
slick When I gave gas on the road, I gave sudden gas with the shift. When the spinning time started at 30 thousand, when I started to skid, how much I pressed the car to the gas, I get gas again after the skidding ends at 30 thousand cycles. what are these systems?
08.05.2020 16:27 # 2
ABS, ASR, ESP !! Now, these abbreviations catch your eye in most places, right? Sometimes behind a vehicle, sometimes in brochures, magazines and newspapers.We wanted to explain ESP, which enhances our driving safety, such as ABS (Antilock Braking System), which is a part of the car owner's life. get safety. A system that keeps your vehicle on the road, prevents it from knocking and helps drivers a lot. If you want to learn more, let's continue. WHAT IS ESP? We can translate it into Turkish as "Electronic Stability Program". Stability, on the other hand, can be used in terms of stability, stability and stability. In fact, we should not think of ESP as a stand-alone system. ABS (Anti-lock braking system) and TCS (or ASR) (Anti-skid system) both support the ESP system. In other words, the presence of ESP cannot be mentioned in a vehicle without ABS and TCS. The ESP consists of the following electronic sensors and parts. This image has been resized. Click here to see the original size of the image. ABS Hydraulics and Brake Pressure Sensor: These are the parts that detect the brake pressure applied to the vehicle wheels in sudden braking situations and prevent the wheels from locking. Locking the wheels means losing control of the vehicle. Wheel Speed Sensors: These are the sensors located on all the wheels of the vehicle that can measure the speed of each of them separately. Lateral Speed Sensor: It is the sensor that informs the ESP how much the vehicle deviates from its direction and what its lateral speeds are. let's see ... HOW IT WORKS To understand how ESP works, first of all it is useful to know that the driver wants and the behavior of the vehicle is constantly analyzed by ESP. If there is an imbalance between them, ESP takes over. In other words, ESP is constantly active in the background. It only comes into play in critical situations. Let's explain the two situations in which ESP comes into play. Let's clarify the incident. But first, let's watch what is happening in the car if there is no ESP. If you are tired of reading the descriptions, our animation below will provide you with a better understanding of everything. Because ESP works in coordination with ABS. Can I have no ESP installed in my car? However, ESP consists of many sensors and electronic components. All these must be installed by specialists in different parts of the vehicle. This can cost you a little bit. What is practical and economical is that they are installed by the manufacturer during the production of the vehicle. Why do I need ESP? ESP prevents your vehicle from being knocked over in critical situations and crashing. It is beneficial for your safety. Is the main purpose of the ESP system to close the chassis errors that may occur in vehicles? The task of ESP is to ensure the safety of your vehicle in critical situations. The vehicle's chassis system is good, of course, the vehicle is safer and has a comfortable ride, but the ESP system provides extra safety, does not cover up errors. If I have ESP in my car, do I need to change my driving style? ESP is there to support you and for comfortable driving. In critical situations where you cannot be enough, in which situations ESP applies the brakes to which wheel? First case: The brakes are applied to the rear wheel when the vehicle slides forward laterally in a straight line. If the vehicle wants to go left, the brake is applied to the left rear wheel, if it wants to go to the right. These wheels are the front wheels on the outside of the skidding.
08.05.2020 16:27 # 3
I think there was no ESP in ABS 1.6 in HDI Comfort, but I may have heard that there is an ESP connected to ABS in the barrier?
08.05.2020 16:27 # 4
06OzGuR06
Flashing light ESP light yes. ESP is already a system that works connected to ABS. In short, it is activated when the speed difference occurs between the wheels. It tries to equalize the speeds of the wheels.
08.05.2020 16:27 # 5
yavuz25
"Wink" Most common Let me say as follows; esp system is running. Be comfortable. No trouble.
08.05.2020 16:27 # 6
ose
I think it is ASR, not Esp. Skidding is disabled. If there is no Asr, there is an electronically controlled differential lock, so when one wheel is idle, it gives the power equal to two wheels.
08.05.2020 16:27 # 7
yavuz25
[QUOTE = ose] I think it is ASR, not Esp. Skidding is disabled. If there is no Asr, there is an electronically controlled differential lock, so when one wheel is idle, it gives the power equal to two wheels. name esp. "Wink"
08.05.2020 16:27 # 8
[QUOTE = yavuz25] [QUOTE = ose] I think it is ASR, not Esp. Skidding is disabled. If there is no Asr, there is an electronically controlled differential lock, so when one wheel is idle, it gives the power equal to two wheels. If we take the name of the system esp. "Wink" [/ QUOTE]
Well, did this exist in our 307s? So in Comfort packages? I knew it was not, but after I lived, I started to believe that everything has turned into an urban legend among the Peugeot people: D
08.05.2020 16:27 # 9
yavuz25
There is a class called intermediate production. My passing uncle bought bipper. 2 months later I went and looked at the bippers where he bought it, but I could not see a vehicle with the same equipment, I asked the seller and said that they were intermediate production. The lamp flashes only when esp intervenes in our car.
08.05.2020 16:27 # 10
[QUOTE = yavuz25] There is a class called intermediate production. My passing uncle bought a bipper. But the beep sounded strange. When the esp intervened in our car, the lamp flashes only. [/ QUOTE]
the event has developed like this. Now you say that ESP is something, so is there ESP? And what a crazy question if I wanted to activate this ESP myself: I need to do it "Shocked"
08.05.2020 16:27 # 11
yavuz25
esp is activated when you want it, not when you want it. "Wink" "Big You have nothing to do. Look at you driving.
08.05.2020 16:27 # 12
Serdar
Does the ESP vehicle need an ESP button? I have ESP in my vehicle and I can switch it off when I don't want to have a button. This means that there is an ESP button if there is aeacra.
08.05.2020 16:27 # 13
ose
Having ABS and ASR does not indicate that EPS is also. Ok eps works with the help of these, but we can not say that there is definite EPS, if I am not mistaken, you do not have the EPS button. What lights are on when the ignition is turned on? Can you write a letter? Also can you write the properties of your vehicle to signature?
08.05.2020 16:27 # 14
[QUOTE = ose] Having ABS and ASR does not indicate EPS. Ok eps works with the help of these, but we can not say that there is definite EPS, if I am not mistaken, you do not have the EPS button. What lights are on when the ignition is turned on? Can you write a [? / QUOTE]
you have to wait for 5 minutes and come down to the parking lot
08.05.2020 16:27 # 15
06OzGuR06
The vehicle with an ASR system does not skid at all, this vehicle is skidding. exact.
08.05.2020 16:27 # 16
[QUOTE = xSOLOx] [QUOTE = ose] Having ABS and ASR does not indicate that EPS is also. Ok eps works with the help of these, but we can not say that there is definite EPS, if I am not mistaken, you do not have the EPS button. What lights are on when the ignition is turned on? Can you write it? [/ QUOTE]
You have to wait for 5 minutes I come down to the parking lotmmmm [/ QUOTE]
ABS-AİRBAG-Error Lamp-Motor but ASR & nbsp; ESP mi ne o & nbsp; lamp did not light up :( xSOLOx 2011-12-17 19:55:51
08.05.2020 16:27 # 17
06OzGuR06
When the ignition is switched on, the ESP light is not on, I think only ABS is on. Is there a key named ESP off?
08.05.2020 16:27 # 18
yavuz25
[QUOTE = Serdar] Does the vehicle with ESP need to have an ESP button? I have ESP in my vehicle and I can switch it off when I don't want to have a button. This means that there is an ESP button, I don't know if it does not exist. automatically activates when the car exceeds 50 km / h.
08.05.2020 16:27 # 19
yavuz25
[QUOTE = ose] Having ABS and ASR does not indicate EPS. Ok eps works with the help of these, but we can not say that there is definite EPS, if I am not mistaken, you do not have the EPS button. What lights are on when the ignition is turned on? Can you write a letter? Can you write the features of your vehicle to the signature? [/ QUOTE]
abs and asr are the lower arms of the Esp general system. /smileys/smiley2.gif "height =" 17 "width =" 17 "border =" 0 "alt =" Wink "title =" Wink "/>
08.05.2020 16:27 # 20
yavuz25
[QUOTE = 06ÖGGRR06] ASR system does not skid, this vehicle is skidding. ESP applies a brake force to the spinning wheel when one of the wheels is spinning. ABS ESP is available for sure. [/ QUOTE]
The information you provided is absolutely correct. "Wink" Asr (with esp) synchronizes the wheel cycles and continues this situation until I get out of the skid. Perhaps it may be century.
Page : / 4
