what is this malfunction sign?
08.05.2020 17:36 # 1
denizkartali06
friends, I reset the maintenance odometer of the car, the lamp went out. It was 9910 when it should look 10000.
denizkartali06 2013-05-18 11:47:35
08.05.2020 17:36 # 2
denizkartali06
http://i1287.photobucket.com/albums/a627/denizkartali06/20130517_173804_zps1dd287e9.jpg
08.05.2020 17:36 # 3
denizkartali06
I couldn't understand this kind of painting either.
08.05.2020 17:36 # 4
Bunyamin.Kar
This is the catalyst light
08.05.2020 17:36 # 5
denizkartali06
what does it mean
08.05.2020 17:36 # 6
denizkartali06
No one knows friends.
08.05.2020 17:36 # 7
Zagorka
Yes This Catalyst Light Is Solved If You Clean The Throat Butterfly.
08.05.2020 17:36 # 8
denizkartali06
thanks..
08.05.2020 17:36 # 9
This sign is a motor fault sign. Your car's brain has malfunctioned. No error messages appear on the trip computer? Check the oil water of your car.
08.05.2020 17:36 # 10
denizkartali06
I just changed the oil of the vehicle 1 week. I didn't see anything on the screen ..
08.05.2020 17:36 # 11
[QUOTE = denizkartali06] I just changed the oil of the car 1 week ago. I didn't see anything on the screen .. [/ QUOTE]
Check the oil level and see how. Was the oil filter original?
08.05.2020 17:36 # 12
Burak
This sign appears in every vehicle as an engine failure. You can find out the most accurate solution by connecting it to the computer.
08.05.2020 17:36 # 13
cerci07
[QUOTE = koliva] This sign is a motor fault sign. Your car's brain has malfunctioned. No error messages appear on the trip computer? Check the oil water of your car.
+1 engine malfunction light
08.05.2020 17:36 # 14
cocomo
there may be hundreds of reasons.
08.05.2020 17:36 # 15
rolandgarros
I lit it for a while and went out in the evening.
08.05.2020 17:36 # 16
ahmet_bjk
This engine is a malfunction lamp. Take your vehicle to the place where you are maintained and get them connected to a computer. It is understood what the problem is.
This sign is also on my vehicle. P0104 air flow meter malfunction when I connect.
08.05.2020 17:36 # 17
Burak
[QUOTE = rolandgarros] lit me for a while, it was extinguished in the evening.
If it is extinguished, the malfunction is fixed. Nevertheless, the vehicle takes it into memory and is found when looked at in the service.
08.05.2020 17:36 # 18
rolandgarros
[QUOTE = Burak044] [QUOTE = rolandgarros] lit me for a while, it was extinguished in the evening.
If it is extinguished, the malfunction is fixed. Nevertheless, the vehicle takes it into memory and is found when looked at in the service. [/ QUOTE]
I probably did not buy lpg from a different place Smile now I'm always getting from the same place no problem thank goodness
08.05.2020 17:36 # 19
denizkartali06
friends yesterday the weather was hot, the screen was dim, I could not notice, this morning it wrote "Antipollition fault" on the main screen.
08.05.2020 17:36 # 20
eserli2008
the same fault light was on me, it was giving the codes 00130 00131, I removed the oxygen sensor, I cleaned it, the light went out, after a while, it turned on the light again, I think the sensor will change.
