What is this? Headlight Heating?
08.05.2020 19:42 # 1
alfonsoxxx
Friends, it takes 2-3 months and I use the second vehicle from vacation to vacation. I can activate after lighting the dipped headlights in this small headlight, it has no contribution to lighting.
08.05.2020 19:42 # 2
usta307
My brother has fog in the headlight in 307. There may be fog.
08.05.2020 19:42 # 3
talip206
The sign on the arm is the fog light release button. The headlights can be turned on when turned on. It does not turn on when the headlights are off. When the fog is on, the front and rear fog mark appears on the instrument panel.
08.05.2020 19:42 # 4
alfonsoxxx
As you said, the headlights can be turned on clearly, something like this is on the screen (the picture is below).
08.05.2020 19:42 # 5
talip206
http://forum.peugeotturkey.com/forum_posts.asp?tıd=8265
There are dashboard signs here. front fog is in the front bumper, rear fog is in the rear bumper. The rear fog is standard, so you will see that lamp light up in the rear bumper. Probably there is no fog light in front of you. You will see it anyway :)
08.05.2020 19:42 # 6
mimit
In that part, you have your front fog lights, not the dipped headlights, the parks should light up closely, there is not a huge lighting power, because the fog lights can only be weaker than they should be due to the fact that the bulbs and the headlight have lost their lighting power based on the age of the vehicle. The fog is not compelled to be in the bumper, and the first doblons are located inside the headlight in the front lighting part, for example. visual and functional changes may occur depending on the model year and equipment levels of the vehicles.
08.05.2020 19:42 # 7
alfonsoxxx
[QUOTE = talip206] http://forum.peugeotturkey.com/forum_posts.asp?tıd=8265
There are dashboard signs here. front fog is in the front bumper, rear fog is in the rear bumper. The rear fog is standard, so you will see that lamp light up in the rear bumper. Probably there is no fog light in front of you. You'll see it anyway :) [/ QUOTE]
Vehicle 307 xt 2004 There is no fog in the rear, there is no fog in the front bumper. so :)
08.05.2020 19:42 # 8
talip206
I thought like 206. I even knew that in the 307s. I even remembered that I saw 307 with fog lights in the bumper. Anyway, we learned something more :)
08.05.2020 19:42 # 9
Mesut48
[QUOTE = talip206] I thought like 206. I even knew that in the 307s. I even remembered that I saw 307 with fog lights in the bumper. Anyway, we learned something more:) [/ QUOTE]
I learned that there is fog in the headlight in Fiat Stilo :)
Now it is out at 307. :)
08.05.2020 19:42 # 10
alfonsoxxx
Apparently, these are fog lights in the headlight, as I thought, headlight heating is not Thumbs Up :)
