What is this, for God's sake someone should say something ...
08.05.2020 16:22 # 1
loiz
I shared it in the forum, my car was black smoke, when I went to samsun for the holiday holiday, the first thing was to go to the pump to the industry. They said that we will replace the repair kit and replace it with a very expensive repair kit. Yanyodu..Injector cleaning additives and without oil, 60 70 km of bottom gas tour come, do not pay much attention to the bass, the bottom gas institution will be cleaned. They said hand (I know my masters, I was at the beginning of the car, I also vouch for their workmanship ..) The war of the car was opened, probably because the catalyst was empty. We got halal for 750 TL. 75 turbo hose-100 workmanship etc.) I got on well, I came to the trabzon .. While the car was still black smoke (it was not as much as it used to be) I got angry. naturally I'm so gassing. (180krş burning car burned 220) still there is black smoke while gas is running. No steady, today I opened the hood to change the parking light. Here is the view across me. jet black soak that there is no soot in the house's heating, so many soot, there was also wetness around the diesel pump, but since the room was dry I did not understand the diesel or threw the naap .. what can I do? help me .. i extended it forgive but help me what should i do?
08.05.2020 16:22 # 2
peugeotefe
If they did not tighten the clamp of the exhaust throat or sheared, it may be because of the institution inside the engine, remove the cover that says hdi, you will see more clearly
08.05.2020 16:22 # 3
loiz
Brother I pulled under the cover, I did not find it on the wire. I said the bottom of the cover or black coal land everywhere, these are just the ones that vomit up through the holes under the cover ... did not remove the manifold in the car? ..
08.05.2020 16:22 # 4
mon
The composition of diesel fuel according to the stoichiometric ratio is C12 H23 per 1 mole. + (O2 + 3.76 N2) If 1 mole of oxygen reacts according to the closed formula of air = 12CO2 + 12H2O + 67.6 N2 & nbsp; The color of the burnt gases changes according to the ratio of N, namely nitrogen in the fuel, as far as I remember from the engine tests. I do not quite understand from kimaydan, but the landa sensor, which determines the mixing ratio in new generation vehicles, comes from this formula. landa sensor; Sensor that informs the ECU of the CO and H2O ratio in the cylinder at the time of the exhaust just at the exit of the exhaust manifold. In the formula: C12 H23 £ + (O2 + 3.76N2).
This is the Landa event, the 1/15 mixture event we know. 1 fuel in the form of 15 air.
The sensor, which informs the ECU about this ratio, if the landa sensor fails to adjust the mixture correctly, the vehicle operates with a rich mixture, so that some of the fuel comes to the exhaust time without chemically burning so that black smoke comes out of the vehicle. Ask the master about this sensor, I think he should have passed.
08.05.2020 16:22 # 5
loiz
thank you for this new information for me ... my master ... oh my master stayed at the sams, i am in trabzon ... no matter what time it is now & nbsp; this car would be under construction ... which will be done .. this is a very serious problem? the gideyimm? Or will we manage until January (until samsuna)? the fuel of the car is a bit too much because i pressed the gas, i always pay attention to the temperature ... the oil is normal, the water is normal, ahh smoke ..
08.05.2020 16:22 # 6
loiz
malfunction update..what is this one say something :(
08.05.2020 16:22 # 7
gozem
There was a similar problem in my vehicle, I immediately took the boshcar service, it was close to 40-50mt, they said that the injector had blown the stamp, the stamp changed, it was 1 year, I gave 50 TL. Maybe I don't know if it's your stamp
08.05.2020 16:22 # 8
peugeotefe
If there is no smoke ahead, on the exhaust side. 1 st probability of the injector washers, 2nd probability, if there is an error in the connection of the exhaust pipe, look at any master of them.
08.05.2020 16:22 # 9
loiz
Brother, I am bored so much that I got to work because of the exams. I went to the car. I went to the village, the car went to the village.
08.05.2020 16:22 # 10
feline
which topya did you go to?
08.05.2020 16:22 # 11
loiz
no ya shentaş-taner i went to the master
the guys worked very well in front of my eyes, i don't talk about their workmanship ... this is what happened ...
08.05.2020 16:22 # 12
loiz
Uploaded with ImageShack.us
this is the bottom of the cover .. I called my master .. no problem walking the car, if you want He said something shouldn't happen if we do it. something like that ... there is a diesel leak! & nbsp;
08.05.2020 16:22 # 13
06OzGuR06
If the fuel consumption is increased, it is a certain injector. But it may also be exhaust. If there is a cuf, it means that the injector is missing the washers.
06ÖZGüR06 2011-11-23 20:12:46
08.05.2020 16:22 # 14
amonse
Do not panic, do not worry, there is nothing to worry about.
