What is this?
08.05.2020 21:09 # 1
Salomalo
mrb friends. In my vehicle, there was an oil leak from the cylinder head and it was changed, but then the problem of misfire started to be rare in the course of high speed driving at idle. Can I have a contact with a broken piece? What is the task of this piece?
08.05.2020 21:09 # 2
the ignition coil condenser teacher may be kicking due to that. If you search for 6555 k9, you can see it on the internet. sonerkyl 2019-02-12 11:23:53
08.05.2020 21:09 # 3
Salomalo
Thanks
08.05.2020 21:09 # 4
Salomalo
[QUOTE = sonerkyl] ignition coil capacitor teacher it may be kicking due to that. If you search for the piece as 6555 k9, you can see it on the internet. [/ QUOTE]
I tied the part but it did not fix the same cylinder cover was removed, the gasket changed, the vehicle's turn turned off I did not understand the fault light is on, the low speed rolentide misfire sometimes makes it going at high speed continuously.
08.05.2020 21:09 # 5
hmm well coil and spark plugs check and idling sensor may be defective. neglecting the throttle cleaning as well.
