What is the tire size compatible with the 206 RC rim?
08.05.2020 16:22 # 1
xpyhre
Hi 206 What is the size of the tire that is compatible with the RC rim? I would be glad if you help thin cheek tires come out how many TL. Reviews
08.05.2020 16:22 # 2
GokhaN
205 40 17. Releases about 100 rubles, the cheapest of which is the cheapest. Zero is around 200 TL.
08.05.2020 16:22 # 3
xpyhre
Thank you.
08.05.2020 16:22 # 4
voodoo
[QUOTE = GökhaN] 205 40 17. Releases are the cheapest in terms of 100 TL. Zero is around 200 TL. [/ QUOTE]
"Thumbs
08.05.2020 16:22 # 5
xpyhre
Master, can we wear 206 gti? would these 206 RC wheels rub against the hood or the windshield? thanks in advance.
08.05.2020 16:22 # 6
voodoo
hangs .... I did not wear it but I saw him
08.05.2020 16:22 # 7
GokhaN
[QUOTE = xpyhre] Master, can we wear 206 gti? would these 206 RC wheels rub against the hood or the windshield? Thanks in advance.
rim is installed. Maybe it takes a little while in a full tour, but if you don't do a full tour, it will not be a problem.
08.05.2020 16:22 # 8
xpyhre
Thank you for your help on the subject. Because in one of the 206 I saw, the hoods were a bit of money, I guess as you say, rubbing the steering wheel by 180 degrees.
