What is the temperature level of 206? |
| 08.05.2020 16:16 | # 1 |
| 08.05.2020 16:16 | # 2 |
In my opinion, the line after 90 is 100 degrees. Also in these 206s, there is a lot of heat problem and the hand moves very playfully. sometimes it gets over 100 degrees in my 206 cars but generally it turns on 100 fans
| 08.05.2020 16:16 | # 3 |
friends, I bought 206 roland garros for 5 minutes. The interior was coming to 100 degrees at low revs. Then the mechanic called the brother said that the belt is finished and changed it from him, so he changed the strap that took 25 TL. After that, my heat did not reach 90. You have the radiator belt & nbsp; I hope you solve the problem by changing it. at least let's see what the situation is over and get a tension check !!!!!
