What is the source of the hum that comes on the way?
08.05.2020 15:39 # 1
metin
Hello friends.
Today I made a long way and humming sounds started to come into the vehicle on the road, I checked everything and still could not find its source. Later on when I was on the road, I realized that when I entered the bends, that is, I turned the steering wheel slightly. What could be the reason for this?
Sometimes it makes the sound on the way, sometimes when I turn it to the right or slightly to the left, it starts to make it, when it is corrected, it cuts sometimes, for example, when I make a very right right, it sounds a little bit when I do it right. It does it only when I have passed over 90 km and when I make it too light right or left. I recorded the voice and waiting for your comments and solutions
Best regards.
I just couldn't add the sound clip. can add friends who can? file link
note: I am not talking about the normal humming sound produced by the electro power steering pump in the 307s, normally this is heard while the vehicle is idle, this sound comes from the scratching breed when driving over 90 km.
text 2011-06-18 22:57:09
08.05.2020 15:39 # 2
ya text brother dear I am so bored now ... there is a void sound in my departures.
08.05.2020 15:39 # 3
[QUOTE = by_ersin] ya text dear dear bored now ... there is a void sound in my departures.
Don't worry about your brother.
08.05.2020 15:39 # 4
bro, I went to every master and dried up 300-400 faints ... Sırıtma
08.05.2020 15:39 # 5
sercinho
text, my brother is past, that sound is going to pull your foot off the gas pedal, do you have the pressure of the gas, try it at the back, let me see the same sound, do you have the same sound in my mind, when you pull my foot out of the gas pedal, you don't normally have a problem in the sansoming, I say that when you get a whirlwind, you say that it becomes a problem when you come back to the corner Could I get to the service with mine, they say there is nothing.
08.05.2020 15:39 # 6
[QUOTE = text] hello guys.
Best regards.
You recorded the voice of your car, but I could not listen.
A similar situation had happened to me because you said humming while driving over 90km.
When I was on the long road, I started to hear the hum on the straight road at a speed of 100-110km, and I noticed that my car started pulling slightly to the right and left, and there was no problem when I reduced my speed. I think the reason for the hum is the wind. I don't know how high your vehicle is from the ground, but at high speeds, the wind is a big factor according to the road condition.
Best regards.
08.05.2020 15:39 # 7
metin
[QUOTE = sercinho] text, my brother is past, the sound of my foot will be pulled from the gas pedal. the same problem can be the same problem. I got it to the service.
Brother my automatic transmission. Just under the console, the steering wheel has a hydraulic unit. When I leave the gas to the pressure, it starts to make a sudden sound, not only when it is cruising.
08.05.2020 15:39 # 8
metin
[QUOTE = mustiii] [QUOTE = text] hello guys.
Best regards.
Best regards.
I uploaded the sound to youtube site, I think it will be awaiting confirmation.
The sound of the wind is definitely not humming while normally idle while the steering pump. This pump sound is thinner and louder. If it comes from the pump, you can't already hear the hydraulics on the back of the engine just under the vehicle, turning the tires. I think the sound comes from here. I think there is a problem in the erection system considering that it does it after 90, because it has a steering system that hardens faster.
08.05.2020 15:39 # 9
metin
actual
08.05.2020 15:39 # 10
metin
actual
08.05.2020 15:39 # 11
Can you give the text youtube link? I downloaded this file but it is not going forward. Shocked
08.05.2020 15:39 # 12
metin
If I can throw it into youtube, I will give (.
08.05.2020 15:39 # 13
metin
sound clip;
08.05.2020 15:39 # 14
voodoo
there may be a problem with the wheel balls ...
08.05.2020 15:39 # 15
metin
If it was not from the ball, it would always do it, for example, I traveled 565 km, the first 135 km did not exist, then it made 300 km and cut it. He has relapsed within the last 100 km.
08.05.2020 15:39 # 16
my friend i listened that sound is sourced from the steering box to me.
08.05.2020 15:39 # 17
metin
I just managed to open the steering fluid cover, if it was in trouble. There is no oil on the dipstick clean, so there is no oil inside the cover. I think, when I looked 2 months ago, I did not understand whether the hose was exploded or not. At the first opportunity, I will take the car on the fiber and check the hydraulic pipes etc. I think we made the steering wheel right or left, and blast it off the barrier
08.05.2020 15:39 # 18
metin
date.
08.05.2020 15:39 # 19
metin
actual
08.05.2020 15:39 # 20
Text belief I couldn't understand the sound of hicbisey. There is an echo sound that comes in between. It doesn't sound very clear. It is not possible to make healthy comments in this way.
Page : / 2
