WHAT IS THE REASON FOR THESE ERRORS FRIENDLY :(
08.05.2020 18:45 # 1
samet2461
For a few days, when I signaled in the vehicle or when I made a selector, the abs fault error and the mileage decreases to zero. The room is not enough When I turn the steering wheel to the left and right, I get an airbag fault error.
What is the reason for these
08.05.2020 18:45 # 2
cavit cevo
airbag membrane will change inside steering wheel 150 TL
08.05.2020 18:45 # 3
samet2461
[QUOTE = cavit cevo] The airbag membrane will be changed inside the steering wheel 150 TL
So may I be getting an abs fault error
08.05.2020 18:45 # 4
samet2461
I'm in great trouble
08.05.2020 18:45 # 5
samet2461
Does anyone know that this is my first time?
08.05.2020 18:45 # 6
Candogar
The vehicle's airbeg coil may be broken. The short circuit that makes it here may burn other error codes. If you do not get the error only in turns, the error is definitely in the vehicle's brain. In the brain, the most logical one would be to buy a new one.
08.05.2020 18:45 # 7
samet2461
There are no problems on the normal straight road, usually when there are roads shaking the very rough vehicle, these problems occur when playing with the steering wheel and the arm.
08.05.2020 18:45 # 8
kuscu38
Look at the steering box if it can be related to airbag or chassis as it says in friends. No, if it turns out to be clean, turning the steering wheel to the left or right, rubbing and breaking on one or more cables due to rubber rubbing may be related chassis. If you want to evaluate, first of all, if there is no solution with an electrician or computerized fault detection, go to the rocket balancer and have the front device and the steering box checked. then you can find the faults and find a solution at the mechanic.
