what is the reason for the sound?
08.05.2020 16:07 # 1
ozi033
I have friends 307 vehicles. When I break the steering wheel to the right and when I turn, there is a sound from the front right. There is no sound on the left side. AlbaYDemircaN 2011-09-14 15:10:24
08.05.2020 16:07 # 2
It can be from any evening in ten teams. Only Z can make rottan. Other joints can give the same sound. Necessary malfunction will occur if you check a qualified rod stabilizer.
08.05.2020 16:07 # 3
metin
If Z had rot, he would make a sound when he entered the pits on the straight road. If the steering is fully broken, it can be on the axle.
& nbsp;
was pleasantly coming on both straight road and turns, I changed the Z rods, there was no problem. the original one should be 30 TL.
08.05.2020 16:07 # 4
[QUOTE = text] If Z rot was going, he would make a sound when he went into the pits on the straight road. If the steering is fully broken, it can be on the axle.
& nbsp;
nice was coming on both straight road and turns, I changed the Z rods, there was no problem. the original one should be 30 TL.
+ 1 & nbsp; "Thumbs
08.05.2020 16:07 # 5
berk2309
flow seals of your problem & nbsp; If you turn it over and press the gas, or click sound clicks, the ruptures are emptied & nbsp;
08.05.2020 16:07 # 6
ozi033
yes, just turn it over and press the gas, it sounds just like that, clicks like this .. I don't know who should I go to for the rot balancer ..
08.05.2020 16:07 # 7
metin
[QUOTE = ozi033] yes, just turn and press the gas, just like that, click sounds like this ... I do not know who should I go for the rot balancer for this solution .. Can you help [/ QUOTE]
& nbsp;
go to a rot balancer let them take the car to the canal and they will list you
08.05.2020 16:07 # 8
berk2309
You come from the big contingent flow, you have blown up the blower blower. My dad does not make it come in the boxer.
