|   | What is the offset of the 307 16 "original 5-spoke wheel? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 14:51 | # 1 |
|  Guests | |
|  are we sure of the offset of this rim?   If the rim will fit, I will look for a set of tires on 195 or 205/50/16. Let me know if you come across. thank you very much ...    | |
| 08.05.2020 14:51 | # 2 |
|  Guests | |
I do not know the offset, but the rim tire pulls together 700-750 rubles together zero zero already. I'd recommend buying 306 gti original wheels instead of this one.
| 08.05.2020 14:51 | # 3 |
|  Guests | |
| The originals of these rims vary between 700-1000 rubles, according to cleaning. There are 700 "lira 16" replica ones, but I do not buy them. Also, even if the tire is over it, it does not heat because it is 205-55-16 because the tires are always up to 307.I also do not want it because it is 15 "in the 306 gti rim, as it is more expensive and it is more expensive. I think it would be suitable price. But I want 16". It would be great if the gti rim had a 16 "model :) | |
| 08.05.2020 14:51 | # 4 |
|  Guests | |
It seems that there is not much that knows the offset of this rim ... I looked at the tool I found was 31 offset. There were 205-55-16 tires naturally, since there were 307 out of them. I said, let's put on the wheel and try it without inserting the tire. we removed the back tire, we put the 16 "rim, the tire leaned on the hood from the inside. The tire on the side of the tire was 7mm from the offset and 13mm from the rim width.   Apparently, we should not use wheels with an offset of more than 20. I think the ten fenders will be more comfortable. The rims in the 306 pictured above are beautiful.   If this friend has used flash or if he has gone, there is a difference in the hub or the offset of the rims he's wearing is different ...  | |
| 08.05.2020 14:51 | # 5 |
|  shamed | |
Is 106 xr offset 25?
| 08.05.2020 14:51 | # 6 |
|  karayel1984 | |
offset
| 08.05.2020 14:51 | # 7 |
|  Guests | |
| what we call offset is a rim related scale. it has nothing to do with the vehicle. I have explained what the offset is before. but let me tell you briefly again ...  if the offset rim is pressed into the hub or the inside of the core surface is correct. I also did not pay attention to how it was in other pugs, but my car writes rim sizes at the sofor door and offset value next to it. The side of the vehicle is the size of the rim on the wheel from the factory. For example, if I install a 14 "5.5" rim with 16 offset on the original rims and 14 "offset" on the original wheels of my car, the rim would be 8mm out. or if the offset of this rim was 32, 8mm would have entered. Of course, this external or thinning event is directly related to the fendership dimensions.   Because the outflow of the glaze surges or stretches very tightly in the stretches, it starts to spur in the glaze on the right and right on the left, as well as the like ...   It will be useful to give you the same information that I have previously explained ...  | |
| 08.05.2020 14:51 | # 8 |
|  karayel1984 | |
Thanks for explaining cecoli. I have read the information you have in the other heading. I speak according to the example you provided. As far as I understand, there is an inverse proportion between the offset measure and the rim outflow of the rim, right?
| 08.05.2020 14:51 | # 9 |
|  alpbeyazi | |
meat is 25.16 '' with the tires usually between 700-1100 pounds.  There are other alternatives, of course. | |
| 08.05.2020 14:51 | # 10 |
|  Guests | |
[QUOTE = karayel1984] Thanks for explaining cecoli. I have read the information you have in the other heading. I am speaking according to the example you provided. As far as I understand, there is an inverse proportion between the offset measure and the rim out of the rim [/ QUOTE]   Yes that's right. As the distance between the rim axis and the hub is reduced, the rim of the rim is getting closer to the axis. hence the rim is pulled out. or vice versa, the offset increases as the offset greatly increases and the hub length becomes shorter and the rim has entered more.  | |
| 08.05.2020 14:51 | # 11 |
|  Guests | |
[QUOTE = alpwhite] meat is 25.16 '' with the tires usually between 700-1100 pounds.  There are other alternatives, of course. [/ QUOTE]  I couldn't understand but when I asked another friend, he said 25 offset to the 5-spoke rim that I was talking about. I called someone else on the phone said room 31. The team I looked at was 31 offsets. There is a madness but I couldn't understand ... I wonder if there are 2 sexes on these wheels, 25 and 31?   I found these 16 "5 arms clean. It was zero on the tire on the rim, but it does not heat. Because the offset is 31 and the tire is too big for my vehicle ... I do not want it at 17" anyway. it is very hard.  | |
| 08.05.2020 14:51 | # 12 |
|  the_beKKo | |
brother 306 gti rim or 206 quick rim wouldn't be better :)
| 08.05.2020 14:51 | # 13 |
|  alpbeyazi | |
How did the 17 rims go hard ... I do not understand what you mean from hard ... 205 * 45 * 17 until I use 205 * 55 * 16, I think, the image is more pleasant. Of course, don't give up on originality, but welcome to the eyes diosan 17 beautiful ... consequently engineer and they found it suitable for both vehicles and 16 jt. Both performance and fuel ...  add: i think your vehicle is 306. i think you try 306 gti rim  | |
| 08.05.2020 14:51 | # 14 |
|  Guests | |
[QUOTE = alpwhite] Where did the 17 rims go hard ... I do not understand what is meant by hard ... 205 * 45 * 17 until I use 205 * 55 * 16, I think, the image is more pleasant. As a result, engineers have installed these vehicles and 16 jt because they found it appropriate. Both performance and fuel ...  add: i think your vehicle is 306. i think you try 306 gti rim  [/ QUOTE]  I am not talking about the stiffness of the rim, of course :) because the tire sidewall is thinning on your tire, the vehicle hardens and clears. This is normal because the tire tends to stretch. 17 "I do not want rim because it is expensive in the rim and expensive, and ten teams often break out. I am not modifying the car anyway. It makes me think.   everyone calls gti rim. I know too, I want the speedline gti rim very beautiful. but they want a lot of money and it is very difficult to find the proper cleaning. either the stroke is straightened or painted. that is why I give so much money to the rim. I found 16 "completely original rickless wheels for the same money. It did not fit my vehicle, but it is a separate subject, but when I get 16" for that money, let me get 15 ".  | |
