What is the 1.4 gasoline 206-liter engine oil?
08.05.2020 20:32 # 1
Karacocuk24
I said, let's have a research today, my friends write 3.2 in the manual on the internet, some say 3.8 in the forums, I could not be sure exactly, I would change the oil, but I would always be happy if the master knew if the master knew clearly.
08.05.2020 20:32 # 2
[QUOTE = Karacocuk24] My friends said I would like to have a research today. It says in the manual in the internet.
It takes 4 liters brothers with oil filter Smile
08.05.2020 20:32 # 3
Karacocuk24
[QUOTE = sonerkyl] [QUOTE = Karacocuk24] Friends said I would search for it on the internet, it says 3.2 in the manual, I am not sure about some in the forums 3.8 I am not sure exactly, I will change the oil, but I will always be happy if the master knows how to knock down 4 liters. [/ QUOTE]
Well, let me ask one more thing, my oil stands 3 or 5mm above the max line
08.05.2020 20:32 # 4
There was never such a problem in my car 206 when I put oil in 4 liters on my car, it was strange. Have you ever disassembled and cleaned the cartel
08.05.2020 20:32 # 5
tsufrankwoli
It changes according to the engine code. Our vehicle gets 3.2 -3.3 with 2000 model filters.
It would be better if it is under the Max line the tsufrankwol 2017-08-29 15:43:50
08.05.2020 20:32 # 6
talip206
3 liter without filter. 3.25 liters if the filter will also change. He writes so in his booklet. 4 do not fill starts to jump from right to left
08.05.2020 20:32 # 7
it means that my 206 was a 2007 model and then increased the engine oil volume Smile
08.05.2020 20:32 # 8
Karacocuk24
In myself, 2000 model, then before I give it to the master, I will sort myself into a clean pet bottle, or it will knock all over, thanks guys.
08.05.2020 20:32 # 9
talip206
[QUOTE = Karacocuk24] In myself, 2000 model, then before I give it to the master, I will sort myself into a clean pet bottle or it will knock all over, thanks guys [/ QUOTE]
They do exactly that. Even if you object, they claim. After that, the oil starts to slip from right to left.
If they are missing, you will add a little bit of yourself.
08.05.2020 20:32 # 10
tired06
When the 4 liter oil filter also changes
08.05.2020 20:32 # 11
Karacocuk24
[QUOTE = tired06] When the 4 liter oil filter also changes [/ QUOTE] no brother broke it from 4 liters to 500ml pet bottle, yet it takes a little over the top of the cube like 3.250 with the filter
