What is Peugeot 307 1.6 HDI Designtech Original Battery
08.05.2020 21:00 # 1
GURCANHORLU
What is the original battery of the Peugeot 307 1.6 HDI Designtech?
My Problem is that The Air Conditioner Is Turned On, The Horn Sound Is Drowning In The Tafric ... After The Air Conditioner Is Turned Off, After A Certain Time Has Been Restored And Its Sound Is Restored ...
08.05.2020 21:00 # 2
GURCANHORLU
Is Varta 12V 60Ah compatible?
08.05.2020 21:00 # 3
First of all, welcome to us. it is compatible, you will not have trouble. but I think water has escaped into your horn, and it probably gets better as it gets hotter. I would say measure the battery.
08.05.2020 21:00 # 4
GURCANHORLU
I changed the horn, I bought the bosch original horn, the event was solved because the car was a 2007 model because of the wear on the corners of the normal horn.
(BOSCH CR-8) Da-Dat Voice Horn Set - 12V Double Plug Socket with original socket made with solder without socket, I had a young electrician brother sitting in the same bench, vala
08.05.2020 21:00 # 5
I'm glad your problem has been improved.
