WHAT IS PEU-206 AUTOMATIC '' S '' MODE
08.05.2020 19:02 # 1
10URAKAR
Hello friends,
My car is Automatic peugeot 206 .... Automatic gears have snow mode and S mode.
Let's understand the snow mode, what is this `` S '' mode.
In other words, there are those who say there is a sport.
But in this real S mode, the vehicle is screaming a lot, as if the gear is running late.
What is the use of this, should we use it or not?
or where should we use .. LOL
10URAK is 2015-01-27 13:37:17
08.05.2020 19:02 # 2
206quik09
as you said, there is s mode for hard use and serial use. If they are normal, let's say 3000 at the s mode, 5000 6000 de gears will be used for high speed.
08.05.2020 19:02 # 3
muro_60
If it is late, it is sport use
08.05.2020 19:02 # 4
mertcan0000
When you need to overtake or accelerate when the speed of the vehicle is low, press the s button accelerates the vehicle to a lower gear. In fact, when it gets very useful :)
08.05.2020 19:02 # 5
Efe-Pojo
It is the "snow" mode that I know. In other words, in snowy weather, I knew it was a mode that shifts gear very quickly so that the car does not fall into skidding, but maybe it is the sport mode in 206.
08.05.2020 19:02 # 6
Barut
S sports mode for cyclic tough use.
08.05.2020 19:02 # 7
hasanxs
[QUOTE = 206quik09], as you said, here is hard and there are s modes for serial use. If they normally throw at 3000, let's say it shifts 5000 in 6000 s mode to use high speed [/ QUOTE]
doing the same when you press the gas to the end without pressing the key
08.05.2020 19:02 # 8
SDYMZ
[QUOTE = hasanxs] [QUOTE = 206quik09] as you say, it's hard and it has s mode for serial use. If they normally throw at 3000, let's say it shifts 5000 in 6000 mode in s mode to use high speed [/ QUOTE]
It does the same thing with hard pressure on the gas, but when it starts to use calm, it returns to normal after a certain time.
08.05.2020 19:02 # 9
pierson
I used the sports mode for the first time ... I was a little scared .. the time passed almost 5000 .. would you mind .. if I pressed it again, was it in my cycle or would I burn the car
08.05.2020 19:02 # 10
blntctn
[QUOTE = pierson] For the first time, I used the sports mode ... I was a little scared ... almost 5000 passed .. would you mind ... if I pressed it again, would it be my cycle or would I burn the car [/ QUOTE]
I think nothing happens sports mode is for use at high speed but I don't understand much, but for a long time the high speed is not good, also the war in your vehicle should be 6500 in general. .
08.05.2020 19:02 # 11
talip206
Peugeot gearbox is sensitive and I say using it as much as possible. I think you consume too much fuel and it is not worth taking risk. Snow mode is nice, I think it works. But sports mode is a risk for our transmissions
08.05.2020 19:02 # 12
ekinoks44
I used the S Mode when I needed to overtake or when I needed a sudden speed. I think there is no need to force the gearbox too much. Sensitive already.
08.05.2020 19:02 # 13
tetik-soner
I used the s mode once the water hose exploded:) ... maybe it was meant to explode ..
