What is HDi, how does it work, how much burns ...?
08.05.2020 14:01 # 1
The year 1959 ... Peugeot 403 exhibited at the Paris motor show went down in history as the first diesel car to be mass produced. Year 1998 ... Peugeot produced the new generation diesel technology HDi engine. Year 2006 ... Today, with the superior HD technology, very low fuel consumption and the extremely high performance together had the Peugeot`N HDi models, the most preferred cars in Europe and Turkey. Peugeot HDi engines are built on the revolutionary "common rail" high pressure spray system. HDi engines, which are products of high engineering and technology, ensure the continuous flow of fuel with high pressure and perfect control of fuel sprays. HDi technology provides great driving pleasure with its flexibility, torque and power, and reduces fuel consumption, air pollution, combustion noises and vibrations.
How does HDi technology work?
The injectors, which are controlled electronically, are connected to a common fuel supply path, which is kept under high pressure (1350 bar). A very sensitive electronic brain specific to the common fuel system monitors many parameters, including engine temperature, air temperature, atmospheric air pressure, and even the position of the accelerator pedal. Considering these factors, the electronic brain regulates processes such as fuel supply, injection pressure and the speed of fuel injection into the cylinder of the car. The injectors have variable control heads that allow a precisely specified amount of fuel to be sprayed into each cylinder. In addition, the electronic brain ensures that fuel is injected into the cylinders at the right time.
The amount of fuel sprayed and the spray time are adjusted independently of the spray pressure and the cycle of the engine. Parsing these functions:
Preliminary or pilot spraying is carried out in a certain amount and time, and consequently reducing engine noise and the amount of crushed gases discharged by the engine,
It allows the main spraying to be adjusted according to the spark of ignition and the required power output. Fuel Consumption and Torque Information
Fuel consumption and torque information of some HDi models are given below.
Model Fuel Consumption (lt / 100km) Out of City / Inner City / Mixed
206 1.4 HDi 70 hp ------------------- 3.6 --- / 5.5 ---- / 4.3
307 1.6 HDi 90 hp ------------------- 4.3 --- / 6.1 ---- / 4.9
407 1.6 HDi 110 hp ------------------ 4.6 --- / 7.0 ---- / 5.5
HDi: Economic usage and maintenance costs…
HDi engine provides 20% fuel economy compared to previous generation diesel engines. In addition, periodic maintenance intervals and costs are lower than previous generation diesel engines.
This excellent economy is the result of three important ecological innovations.
Common fuel path system ...
The common fuel rail system developed in conjunction with Bosch uses a high pressure pump (1350 bar). The amount of fuel sprayed on the cylinders can be adjusted precisely thanks to the electronic brain. Small diameter nozzles in the nozzles ensure that the fuel is completely evaporated before it burns.
Specially designed combustion chamber ...
The combustion chamber is designed to ensure perfect air circulation and guarantees an ideal fuel-air mixture. This feature contributes to the almost complete combustion of the fuel-air mixture and provides a very high efficiency.
New type of engine oil ...
The HDi engine uses a new type of engine oil to provide high economy.
HDi: Respect for the environment ...
HDi technology and especially "pilot spraying" feature provides more efficient combustion and burning of fuel completely. This means reduction of exhaust gases.
Compared to normal standards, HDi engine provides 20% reduction in greenhouse gases (CO2), 50% harmful gases and 50% soot particles. The HDi engine contributes to the protection of the environment.
08.05.2020 14:01 # 2
sinan-s
Thanks for sharing ..
08.05.2020 14:01 # 3
Thanks for sharing
08.05.2020 14:01 # 4
hasimayaz
Is there any more than that :)
08.05.2020 14:01 # 5
elenor
thanks.
08.05.2020 14:01 # 6
Ismail
Tskler emrh brother, I never like your voice
