What is edison ed 1000d mono amp? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 18:10 | # 1 |
rizeli_53 |
my brother can lift it. Because the sound is set, you listen for a while, then the amphitheater does not show God. I don't know what model edison is. We connected 2 pieces of 38 sony amphitheater, not immediately after a certain time after loading. good forums |
| 08.05.2020 18:10 | # 2 |
barishrocker |
ohmaj values of bass are also important. |
| 08.05.2020 18:10 | # 3 |
barishrocker |
By the way, if there is no luggage problem, you will get very nice bass with double 30cm sub. Apart from pioneerin, I suggest you re audio. |
| 08.05.2020 18:10 | # 4 |
barishrocker |
with this edison, you fully feed only one pioneer sub. 2 is insufficient. Which of these products do you have or are you planning to buy? |
| 08.05.2020 18:10 | # 5 |
barishrocker |
jameson wants 4ohm 450w power. The amp gives 310ohms of 4ohm. edison and jameson steal the sub, but not fully. If you are just starting out, it will satisfy you. |
| 08.05.2020 18:10 | # 6 |
barishrocker |
If you have 2 pioneers, use them. Get an amp that gives at least 800rms of power at 1ohm. it will play better. for example, digiline dga 1001 can be purchased. It gives 1000rms of power in 1ohm connection. sublar will play very strong .. likewise there is forwell op 1000, it will ring well ... |
| 08.05.2020 18:10 | # 8 |
barishrocker |
I think the 1ohm link in the picture has been descriptive enough. but still it is useful to install it to the person who knows. Meanwhile, I searched the amp, I saw that it is written as 1ohm 1000rms on some sites. |
| 08.05.2020 18:10 | # 9 |
barishrocker |
you ask what it means .. what does it matter after not transferring the information :) by the way, this link is valid for 2 pioneer subwoofers, no mistake. If jameson is going to be installed, the only option is a 4ohm connection. the power of the amp is not enough for him, but it knocks ... |
| 08.05.2020 18:10 | # 10 |
barishrocker |
yes it would be nice :) By the way, we make this connection only in 2 double coil 4ohm. If it is 2ohm for example then 1ohma does not drop :) I said, or this is like a math problem: D |
| 08.05.2020 18:10 | # 11 |
EmSul |
Yes, omaj calculations are actually very simple, but of course, it is very simple compared to electric electronics. Also, the bass you will connect must be the same, or if you connect a bass with 2 different rms value, it is likely that the one with low rms will burn. Do not take my amplifier, go get edison, then it is burned when you connect this 1ohm and don't turn back to me :) This is a joke but of course, the Edison amplifier is not stable in 1 ohm, although it is not stable, it is not as stable as 1000rms in 1ohm and it is not a device that can give power. stabi was not l, these new series are worse .. Digiline dg-1001 - Forwell op-1000 - Pilippo po-900 - Audiostation as10001d - the cheapest 1ohm stable c class amplifiers Also, I think that a single bass experiment with a mono amp will be enough in a single bass. |
| 08.05.2020 18:10 | # 12 |
barishrocker |
I couldn't trust edison too :) the amps you count are good for the price. I would like to know electronics.
| 08.05.2020 18:10 | # 13 |
barishrocker |
[QUOTE = 307bursa] by the way, if you understand the link, I have 1 more question :) Now, streo amplifiers audio connection cables come from the tape here 2. When connecting the amplifier, will my cable be pulled from the tape again, or will my bridge be taken from the other amplifier and the same installation will be drawn again in energy? I just saw it, sorry. If your power cable is 0, 2 or 4awg, splicing can be made from the same cable. But if it is a thinner cable like 6.8, I think it will be pulled again. Take a couple of other RCA cables to the amplifier. Of course there is enough output in the tape Necessary;) |
| 08.05.2020 18:10 | # 14 |
EmSul |
I guess it is not the power cables that the friend is talking about, but I think the audio cables are very good. |
| 08.05.2020 18:10 | # 15 |
barishrocker |
We ask you ... in order to inform the forum, I think share your system. it will also guide other friends. I even photograph the stages of the systems I built. |
