What is Chip Tuning?
08.05.2020 14:12 # 1
cankurts
It is an arrangement regarding the ignition system applied to gasoline vehicles with chip tuning injection system and turbo diesel engines with electronic system. The process of producing more power and performance by providing an increase in torque with the change made in the ECU (Electronic Control) unit is called chip tuning.
While many advantages can be provided from fuel saving to engine power increase with chip tuning application, there are disadvantages such as high cost and difficulties of returning from application. For this reason, it should be considered very well before the chip tuning application is decided.
The ideas that the chip tuning application, which can be completed in about 3 hours, damages the engine of the vehicle, are completely unwarranted, the fact that the main application was made by authorized and skillful people, even some car companies provide chip tuning services to their customers at their authorized services.
Chip tuning is a system that does not create any different appearance on the vehicle when viewed from the outside and is only an application to increase the performance of the vehicle. visual applications are coming, but in fact, true modification is always the applications that have a positive effect on the power and speed of the vehicle, so chip tuning is among the top modified applications.
Our friends who are considering chip tuning should consider the advantages and disadvantages of not applying before making a decision, and they should find the most reliable companies by conducting a comprehensive research in order to get their chip tuning.
You don't need to be a modified enthusiast or race lover to have chip tuning, if you are one of those who love my car but say it would be nice if the performance increased without increasing fuel consumption, it is available at the nearest authorized service shops that perform chip tuning.
ALINTIDIR ....
08.05.2020 14:12 # 2
shamed
Thanks
08.05.2020 14:12 # 3
CaN1903
Thank you, but as far as I heard it affects the fuel as much as I heard.
08.05.2020 14:12 # 4
cankurts
In order to get performance, fuel consumption must increase, I can give an example as a logic. In a walking person, 5 km of road goes, but in 15 minutes of running, it goes more than 1 hour and uses more energy than walking. Sırıtma
It was a bit silly, but I think he's telling. Göz Kırpma
08.05.2020 14:12 # 5
CaN1903
heheh yes, he is hungry enough, so the result from here is tired.
08.05.2020 14:12 # 6
Eyup Duygun
[QUOTE = cankurts] In order to get performance, fuel consumption needs to increase, I can give an example as a logic. In a walking person, 5 km of road goes, but in 15 minutes of running, it goes more than 1 hour and consumes more energy than the walking walk. Sırıtma
Greetings, your example does not say that if you press this gas too much, the heat makers do not say they will save fuel. In the use of the software, it is seen that the software is saving according to the characteristic.
edit: a small note chip installation is not in the past, there is no intervention in the brain, the test socket side of the vehicle is possible to throw software from the obd2 socket, but again, low-model vehicles are made with an eprom socket in the brain.
eyupd 2010-04-01 17:35:46
08.05.2020 14:12 # 7
atakanka
So is there any harm to the engine of this event called chip tuning?
08.05.2020 14:12 # 8
Eyup Duygun
As a result, if the settings are made and applied to the engine in absolute terms, but only if the advance and stable values are left in the fabrication, we would be wrong if we expect 110 hp from the 1.4hdi 307 and hope 110 hp.
