What is Carbon Clean? With the Simplest Expression.
08.05.2020 13:55 # 1
Carbon Clean is a system consisting of a machine and cleaning chemicals. One bottle for 4 cylinder engines and one and a half bottle of cleaning agent for 6 cylinder engines are placed in the tank of the Carbon Clean machine. Gasoline (for gasoline engines) is then added up to the mark inside the tank. In order to disconnect the car from the fuel tank, the pipes connecting the fuel inlet and outlet connected to the fuel log are connected to each other. Then the machine's hoses are mounted here. Thus the machine's tank becomes the car's gas tank. The engine is run at idling speed until the prepared mixture is finished, which takes about 30-45 minutes. Once the gas is pressed, the institution removed is removed from the exhaust. The biggest feature of Carbon Clean cleaning chemicals is that they are non-flammable. Therefore, there are no side effects on engine parts.
Carbon Clean is a registered trademark and the patent right belongs to American Motorvac company. This concept, which we started to explain in the form of institutional accumulation and damages in engines in 1994, has created an infrastructure for other similar products to enter the market over time and the process with similar products introduced has actually started to be called the brand of our product, Carbon Clean. None of the products on the market has the properties to make soot as effective as Carbon Clean.
CARBON CLEAN CHEMICALS AND CARBON CLEAN MACHINE in USING THE INSTITUTIONS AND CARBON DEPOSITS CLEARING OPERATIONS AFTER, the CAR TO THE MAXIMUM TORQUE AN IMPORTANT MİKTA INCREASE which PROVIDED, COMPRESSION VALUE OF POWER in and he AVERAGE 27% PERCENT INCREASED TIRES AVERAGE 6% PERCENT YUKSEL that the BOSCH dynamometer TEST RESULTS WITH PROVEN.
- After the Carbon Clean process, your vehicle will run more quietly and quietly.
- Engine noise in your vehicle is reduced.
- 0-100 km of your vehicle. Its acceleration and flexibility capability, which we call intermediate acceleration, reaches the performance values of your vehicle at "0" km.
- You will enjoy high driving comfort and pleasure by changing less gears.
"0" km by consuming less fuel. you provide engine performance.
- Expensive parts in your vehicle's fuel injection systems are prevented from changing unnecessarily at unnecessary times.
- It decreases the maintenance and labor costs of your vehicle and the time of service.
- Especially in diesel vehicles, the occurrence of many faults caused by parts that are very expensive and take time to be replaced is prevented in advance.
08.05.2020 13:55 # 2
thanks for sharing Big 20smil% to
