What is bow fault?
08.05.2020 17:19 # 1
doritos
Hello friends, I am new in the forum. I have a very interesting problem. I have a model peugeot 307 hdı xr model. When I start the car I get 2 error messages, first one is the antipolution fault and the other one is the bow fault, I learned the antipolution error is not important or what it is. But bow fault We couldn't solve a kind of error. I went to the private service, they said it was the first time that we came to us, they searched, they asked right and left, but they could not find it.
What I need your help is this is bow fault, and it is important.
word meaning bow-box-bowl have meanings like ..
< div> Reviews
Reviews
Reviews
Reviews
Reviews < div> Reviews
Reviews
08.05.2020 17:19 # 2
tellotello
I am meeting for the first time, my teacher, I have been reading for quite a while, but I have not encountered any problems. In some foreign sources, it has been said that this is related to the battery, so first of all let me ask if you have recently removed the battery or even put it in the corner as a roof, so to speak. Generally, these types of troubles may occur when the battery is disconnected. I know that the brain, called BSI, needs to be put to sleep before removing the battery terminals. Otherwise, troubles may arise (but of course I cannot describe its direct relationship with the BOW fault event). Also, what is your battery condition? My recommendation is in the header I link below, after the 3-minute rule (apply whatever they say there) after removing the battery terminals, you can try again with a new battery. & Nbsp;
http://forum.peugeotturkey.com/forum_posts.asp?tıd=20338&title=aku-kutup-baslarini-sokerken-3-dakika-kural the
Reviews
As I said, I can not say that it is directly due to this, but there are some English sources I have read that solved the problem in this way, and there is no harm in your experiment. Hope you will solve your problem. May it be easy.
08.05.2020 17:19 # 3
doritos
Thank you for your attention, my teacher, since my car was a little bit propped up, the last repairman I could have played with the battery. The repair work, which started in 9 am, signaled it lasted until 9 am, while trying to lock the trunk, the hard driver broke the door lock, and before the car, the airbag error followed by an antipolution fault, and finally the bow fault error. They delivered the car to me in this way. They said: "I bought the car for the next day because I had to fall on the roads of Kocaeli because of the discomfort of my husband, I came to the road from sultangazi as soon as I arrived at the toll booths, I noticed that the engine part burned, and when the smoke came up, I realized that the engine part burned. I pulled the lord on the safety lane, the hood opened, what I can see is that the whole engine is on fire, blazes a lot of burns.
Anyway, with the help of a tractor, I pulled the car to a private peugeot dealer on the Sanko industrial site. The vehicle remained there for a month, the plastic parts in the engine section were changed. But let's come back, buantipolution fault and bow fault error constantly. It does not go out, it turns off when the ignition is turned off and on again.
