What is an idle socket on the right of the engine
08.05.2020 20:15 # 1
radman206
There is an empty socket on the right of the engine. What is this socket? Does anyone know or guess?
08.05.2020 20:15 # 2
OguzhanKucuk61
Sir, the photos are not visible. Either I have a problem or if you want to check it out in the photos
08.05.2020 20:15 # 3
I feel like they did not dismantle the old one when the heat switch socket changed. can you follow the cable. same head with other plugged socket because
08.05.2020 20:15 # 4
radman206
They come out of the same spiral tube, but I don't know if it's from the same place.
08.05.2020 20:15 # 5
BLACK LION
They may have removed the temperature sensor or the water level sensor. Because the sensor is broken, I saw the one doing so that he wouldn't be constantly warning.
08.05.2020 20:15 # 6
radman206
When it comes out, doesn't it really make mistakes?
08.05.2020 20:15 # 7
sdttn
Is there a sensor in the expansion tank (coolant)?
