What is 308 fuel consumption urgent please ..
08.05.2020 16:08 # 1
Ako06
Hello friends. If you have friends or connoisseurs who use 308, how much do you tell them to burn? I would appreciate if friends who know gasoline diesel does not matter. If you have lpg, it would be great. Thanks in advance
08.05.2020 16:08 # 2
mimitt
vti engines can now be fitted with lpg, a little more expensive than regular sequential systems, if you do not intend to replace your vehicle within 2 or 3 years. it requires more care, it is necessary to take care of it without disrupting its maintenance, as they are turbo-fed, we need to pay special attention to the turbo.
08.05.2020 16:08 # 3
Ako06
thanks .. Please if anyone who uses or knows Lpg li 308. Could you tell me how long the water will cost in LPG? 1.6 engine, for example. Efforts to persuade the father continue. 20 kr & nbsp; will look positive if it burns or below. please help thanks.
08.05.2020 16:08 # 4
mimitt
20 cents is a very ambitious figure for the city. 1.6 120 hp vti ummmm is a bit difficult. It requires a very quiet use. / editID> 2011-09-22 01:05:28
08.05.2020 16:08 # 5
Mıtıt can see how many you can fall into the city in the city ??? Under 6lt seems like a little hard ...
08.05.2020 16:08 # 6
mimitt
I have dropped to 4.7 in heavy traffic flowing in the city, but even in the far right lane you can eat the selector ozmn, but normally it burns between 5.5-6 liters. huh, you can reduce it to 3.7, but the speed should change between 50 and 70. In the city max 70km .I tried the first time I bought the car. I would not give up for 308 unless 307 hdi is 0.
08.05.2020 16:08 # 7
[QUOTE = mimitt] I have dropped to 4.7 in heavy traffic flowing in the city, but even in the far right lane you can eat the selector ozmn, but it normally burns between 5.5-6 liters. huh, you can reduce it to 3.7, but the speed should change between 50 and 70. In the city max 70km .I tried the first time I bought the car. I would not give up for 308 unless 307 hdi is 0. [/ QUOTE]
& nbsp;
I spoke to a friend late, saying that 308 hdi does not fall below 110 u 6lt. it showed 6.3 in the information .. DIV> A gasoline automatic vehicle with a friend is considering the LPG. In my opinion, it does not burn down to 25kr in the city and can reach up to 30 kr according to the usage style. I suppose it does not fall below 11 liters in gasoline. This is 50 kr.
& nbsp;
There are examples as well. Automatically 307s do not fall down 25-26 kr. as well as recently in the lpg. 2.40 TL
08.05.2020 16:08 # 8
mimitt
cem, 308 hdi is much more economical on the long road, but it is almost the same with the city 307 hdi. As I said, if the aim is only economy, it is necessary to find 1.2 1.3 gasoline / lpg li, or 1.3 1.4 diesel, they have automatic models. I think vehicles like corsa 207 polo in segment b can be a bit more economical in lpg
08.05.2020 16:08 # 9
Ako06
thank you very much for your help. 307 diesel is not alone. Lpg li. room 24-25 kr. Burning. But my father says this number too. But considering what you say, it seems a bit silly to switch to 308 for fuel economy.
08.05.2020 16:08 # 10
mimitt
friend, please explain this to your family elders in a proper language, I understand the same because I live the same, if you find a car that is burning 20 cents today, it will gradually go as 21 22 23 in a month or two, I was catching the numbers you want very easily when I first bought the vehicle, but now diesel 3.70 3.80 shell gtl diesel 4.00 lira.
08.05.2020 16:08 # 11
There is absolutely no need to change the vehicle. Now, if we turn off this money calculation, we'd better. Calculating fuel over Turkish lira is ridiculous in this period. Prices change every day, like the free market economy, or there is a continuous hike. Everyone who says my car is burning is a lie, because it was yesterday today. For this reason, it is necessary to talk about the fuel of the vehicle in liters. I have 307 sw 90 hp (1468 KG) if you do not press in city use, 6.0 lt does not fall below 6.5 lt if I use cycles. I think these values are beyond excellent. I think it is necessary to change the segment to reduce fuel.
