What if i do peugeot 306 radiator side cover untouched ??
08.05.2020 17:54 # 1
volkan22
Good forums, I have a 2.0 auto transmission radiator, and I have a small hole on the side cover of it.
He closed the radiator, and the water on the right side of the cover is running like a stream. I brought it again. This plastic cover says it will not be bent. He took the money in my money ...
Will I have a problem with the industry tomorrow to make the right right cap completely copper?
Note: The plastic cover on the right side is on the battery side. I would appreciate if you can help with advice.
08.05.2020 17:54 # 2
Bunyamin.Kar
Hello there,
I didn't understand what you meant when I said the radiator side cover. Radiators win if referring to the plastic part you do not have anything to do there already radiator industry 135 TL, I bought it, I won the top was cracked flattered when I changed at the end I used adhesive pasting, I found the same thing at first looked out, but the bottom was not to the SEGMENT output mine oblige I bought the sub-industry recently, I found it to be 50 TL for a solid price.
08.05.2020 17:54 # 3
error
If you find a master with a decent handwork, he will do whatever it takes to perform the necessary repairs, but he will fix it, but you must find a master with dexterity and time.
08.05.2020 17:54 # 4
volkan22
Unfortunately, I am staying in Cyprus.
Even the pin that holds the hose at the top of the simplest thermostat cover does not exist in pejo service and anywhere :(
