What i want to do 307
08.05.2020 14:55 # 1
kabus
Hi friends, I have 2003 model white 307 1.4 hdi, I would be very happy if you help me what I want to ask, right now I use original 195/65/15 cover rims 15 inch I want to put on a steel rim. As the vehicle is 1.4 70 hp, I do not want to put on a big rim and make it cumbersome. I want to expand the tire tread a little and reduce the tire sidewall. It will not decrease the performance of the vehicle. It will not change its comfort. Accordingly, which tire size do you think is the most correct? 1-205 / 65 / 15.2-195 / 55/15 actually seems to me the most logical option 2, but if you have other suggestions, I am waiting.
Another issue is that I want to paint the front and rear bumpers, since there are paint clutches on the bumpers, I also want to paint the side belts, side mirrors and door handles. Currently, the door handles and mirrors of the car have these cheesy chrome finishes. Will there be traces of glue when it is removed, will there be a bad image when paint is removed? I was going to do it in white then I gave up because everyone is doing the same thing I want to complete with the flat black rim red strip and black led stops
In the meantime, I am waiting for your suggestions from the black rim brand model, it will not be too expensive, at most 800 TL finally 3.5 cm I want to wear a spring, what is its price, but I do not know if I get too close to the ground, our roads are a little bit bad engine mod, only the best performance to be performed by tuning the chip. Waiting for your valuable answers. Thank you.
08.05.2020 14:55 # 2
the tire will be 205-55-16. The second option is small to the vehicle of measurement. you can use that tire only in 206 306. no more research is required. If you pay attention, I have already told you the tire size in the 307s with the original 16 "rim.
08.05.2020 14:55 # 3
kabus
[QUOTE = cecol of]
Thanks, but I have 195/65/15 rims on the vehicle right now. I don't want to go over the original 15 rims. The car is 1.4 hp 70 hp so if I install 16 rims, the rim will grow and the tire base will expand. ??
08.05.2020 14:55 # 4
dogu
No adventure search, continue with the same dimensions.
08.05.2020 14:55 # 5
kabus
I am not looking for an adventure anyway, I explained in detail above.
08.05.2020 14:55 # 6
coyote26
If the chip is to be made to the vehicle, it will not be 16 inches big. The same car has the Wimmer RST software9. If you say you are looking for adventure, do not ignore Chiptuning and decide accordingly according to those who are looking for adventure.
08.05.2020 14:55 # 7
ali oncu
I think it shows 16 more beautiful, but you know.
08.05.2020 14:55 # 8
kabus
[QUOTE = coyote26] If the chip will be made to the vehicle, it will not be 16 inches big. The same vehicle has the Wimmer RST software9. .... 3.5 cm is not very close to the spring, you can use it very comfortably, I would say you buy 16 in the rim, you are not in favor of the rim buyers. ... [/ QUOTE]
Thank you that you enlightened me. I want to go over the current performance. With Chip, so I do not want to enlarge the rim size. For me, the image will stay on 15 rims in the second plan. My tire size is now 195/65/15.
The 15 steel wheels I will attach will look a bit small, so I think 195/55/15 tires to make the rim a little more pronounced. How can I think that it would be better if it was a little wider but this time it would be a little lower in performance because the tire tread widens. I am waiting for an answer in other questions thanks
nightmare 2010-10-11 17:37:18
08.05.2020 14:55 # 9
coyote26
what do you mean ....
I think you do not buy any 15 wheels fins .... Get the original 5 arms 16 inches rim of the 307 Do 205-55-16 tires plug in the chips, make 3.5-inch springs, stop the car very sweetly. You will not be a pimp, you can take 15 wheels and stand out because the hard rim will suppress the rim and the rim will remain in the background.
08.05.2020 14:55 # 10
kabus
[QUOTE = coyote26]
well thank you then 205-55-16 is the right choice
08.05.2020 14:55 # 11
coyote26
ewet the right choice original 5 arm 16 wheels find 3.5 high plateau very sweet stop vehicle
