WHAT HIS FRIENDS HELP ME
08.05.2020 16:47 # 1
koruclu
FRIENDS NBENM ARABAM PEJO 307 2004 MODEL DIESEL:
& nbsp; CARS my BUY FUEL to CONTINUOUS SHELL TWO WEEKS BEFORE A DIFFERENT STATION ALT AND CAR's DRIVE TO ZERO INDEX OF INDUSTRY I GO BANANA my TANK was CLEANED FILTER CHANGED TRACTION that NEED IMPROVEMENT SAID USTA UNFORTUNATELY REPEAT THE SAME PROBLEMS AGAIN NEXT AFTER WHEN I GO TO THE MASTER, THEY SAY THAT THE AIR FLOW SHOULD HAVE CHANGE IN THIS AIR AND THE PROBLEM IS CONTINUING
& nbsp; & nbsp; When I GO TO A DIFFERENT MASTER, I MAKE DIFFERENT DIFFERENT EXPENSES AND THE PROBLEM IS NOT DISAPPEARED. & Nbsp; MASTER FRIENDS UNDERSTANDING THIS JOB CAN YOU HELP FOR GOD REGISTRATION. SOMEONE HAVE BEEN AFFECTED TO TAKE THE INJECTOR FALAN, I HAVE BEEN FARNED TO TAKE REPAIR. I WAIT FOR YOUR YAROMS ..
08.05.2020 16:47 # 2
toGah
I wonder if you looked at the turbo or not.
08.05.2020 16:47 # 3
teoman_40
there is a possibility of being from a turbo, I say "let's say ..."
08.05.2020 16:47 # 4
yigit4516
can it be injectors?
08.05.2020 16:47 # 5
cerci07
If there is an excessive power loss, it may be from the turbo
08.05.2020 16:47 # 6
lew40
most likely my injectors friend check them out, turbon is probably ...
08.05.2020 16:47 # 7
koruclu
ESPECIALLY THE CARS ARE VERY FALLED ON THE RAMPS AND THE FUEL CONSUMPTION IS ALSO MORE.
08.05.2020 16:47 # 8
oguzhan29
can be turbo or injector
08.05.2020 16:47 # 9
istanbullu_3886
If my friend has a great past, the thing you are experiencing is not that you will change the diesel and continue it. I think if there is water or something in the fuel, the fuel system needs to change completely.
08.05.2020 16:47 # 10
istanbullu_3886
If you have a receipt for the station that receives that diesel, if you have a report that proves that the malfunction is related to the dirty diesel, you should apply to the court if I do not.
08.05.2020 16:47 # 11
snow
I once had a reno seymbol in diesel & nbsp;. He said he would burn the engine. I just got the turbo built. snow 2012-05-21 08:46:54
08.05.2020 16:47 # 12
toGah
I recommend you to find a competent master of priority, they will give you to butchers as they go, there is another problem. & nbsp; you change it in the turbo, you change it in the injector, but you can't find a solution, then you have money going out. even 1-2 turbochargers. Not pjo service. & nbsp;
find turbocharger
08.05.2020 16:47 # 13
turbo27
I do turbo work in Taksim closet, if you stop by, we will find the malfunction in 15 minutes, and we will have tea and meet him. 0542 658 26 27
08.05.2020 16:47 # 14
onur3434
I think it's from the injectors. poor quality diesel injectors break down performance drops fuel increases ..
08.05.2020 16:47 # 15
kuzu
If the 307 1.4 hdi gets up very hard in 1st gear, there is no traction in the 2nd gear, the catalyst may be clogged. The disease of 1-4 people may be a problem in the injectors if there is a lot of clogging, especially between 2500 rpm and 3000 rpm.
08.05.2020 16:47 # 16
Lion46
I recommend you to have your vehicle checked in a service with pp2000 and find a solution according to the malfunction code that occurs.
08.05.2020 16:47 # 17
pug61
my friend and my close friend also had the same problem 307 1,4 hdi 2004 model vehicle did not exceed 120, the problem appeared in the air flow meter, I say, look at it.
08.05.2020 16:47 # 18
turbo27
Are you sure you are dusting immediately after buying diesel from another place? If you are confident that the fuel may have broken the injector nozzle or valve, if the dirt has come to the injector, your vehicle will run unbalanced at idle, pay attention to this, while it is idle, give up to 3000 cycles of gas slowly, whether your eye is at the hour, this gas is given in a certain period of time. If the car dropped out of the car accidentally rather than fuel, a lot of reasons are sought, but you say that the air flow meter has changed, I bypass the air flow, check the turbocharger kacak & nbsp; can, air filter & nbsp; it may be clogged, the catalyst may be filled, it may be clogged, the diesel filter may be clogged, if there is smoke, your vehicle is black or white, check them, then we will try to help with friends in the form ...
08.05.2020 16:47 # 19
osman_bora
shell v & nbsp; power gtl diesel do not be surprised friends i have peugeot 406 2.0 diesel i was constantly buying from opet shell v-power diesl gtl i searched used the engine's voice change is softer, i didn't notice anything on traction, km goes more, don't mind as my master says Don't get fuel from the FULL gas station ..
My friend is probably a turbo to fall out of traction, but as the friends write, there are a lot of reasons but I would consider the comment of turbo27.
08.05.2020 16:47 # 20
tigerland
have the turbo hose checked & nbsp;
Page : / 2
