What happens if water gets into the engine oil? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406 | |
| 08.05.2020 16:40 | # 1 |
| 08.05.2020 16:40 | # 2 |
If the oil mixes with water, it also mixes with water |
| 08.05.2020 16:40 | # 3 |
You think right, it can be observed from the expansion tank. Also, when you open the oil cap, look under the cap if there is a creamy layer like tahini, there is a high probability of leakage. It is also a serious situation that I know is serious. have a look at a service
| 08.05.2020 16:40 | # 4 |
muratoner |
The block cracks. The gasket burns. It is so simple but too expensive.
| 08.05.2020 16:40 | # 5 |
This is the simplest observation of the vehicle that reduces water. The gasket changes, the cover is grinded etc. The cost does not exceed 500 TL.
| 08.05.2020 16:40 | # 6 |
I thanked those who commented
| 08.05.2020 16:40 | # 7 |
cerci07 |
If there is an oil level increase, it is water or if the vehicle is diesel, it is oil. If it is water, it is like oil mayonnaise. If it is diesel, it does not change color in any way.
| 08.05.2020 16:40 | # 8 |
[QUOTE = laedri] This is the simplest observation of the vehicle, which reduces water. Gasket changes, cover is grinded etc. Costs not exceeding 500 TL. [/ QUOTE] absolutely correct detection! |
| 08.05.2020 16:40 | # 9 |
I think I have the same problem .. is there any possibility after the radiator has changed ..? After replacing the radiator, I saw that the vehicle was throwing water from the exhaust (no drips but watering with the exhaust) water ... I just noticed the situation ... I said it was from the radiator but ... I guess it wasn't .. well, it is necessary to look at it as soon as possible. Should it go as far ..? & nbsp;
| 08.05.2020 16:40 | # 10 |
istanbullu_3886 |
[QUOTE = toga406] Does anyone know what happens when friends mix water with oil? is there anything happening to you |
| 08.05.2020 16:40 | # 11 |
from the cylinder gasket. source div> |
