What happens if the valve setting is bad?
08.05.2020 17:53 # 1
samet206
Hello friends, when I open the right door from the right side of my vehicle, the sound comes in a fast way, click it, it does not go to the clutch at the idle. I knew that I showed today, the valve setting is crazy, they said, I was surprised, I did not see shaky work, no shower, no shower, no shower, no pressure, but I did not see the pressure pad, the car got stiff, maybe I can not see it because of it.
08.05.2020 17:53 # 2
error
As far as I know, a sound coming from the system that presses excess gasoline back into the tank is not a problem.
I think the name is canister
08.05.2020 17:53 # 3
samet206
[QUOTE = errör] A sound coming from the system that replaces the excess gasoline to the tank is not a problem as far as I know ..
Thank you, I will show it to someone else, let's see, there is always a sound in the idle, there was no such sound in the past, in the winters I show you, my gas goes through the hose, what an idiot says to you, I said it, I said 10 winter times, it says the same thing, I said you are different, I did not handle it, how many times I have seen it before, I don't know where it goes through, but I know that different vehicles go through those parts.
08.05.2020 17:53 # 4
error
Well, I don't know exactly, but when the engine is cold, you hear a chirping sound, if the valve is not set, now the valve cluster sounds like you are hitting the opposite side with the opposite sound.
08.05.2020 17:53 # 5
samet206
[QUOTE = errör] I do not know exactly, but when the engine is cold, you hear a chirping sound when the valve is not set, now the valve streak sounds like you are hitting the opposite side of each other, the sound coming from the engine in the gasoline return is more like a crackling before trying to distinguish these two. [ / quote]
I listened but I could not distinguish, let's see exactly, we'll show you again. Thanks for your help, there is no problem starting the first time. When the vehicle is tested, it starts after 10 minutes.
08.05.2020 17:53 # 6
Turgay_66
My engine also has a little click where we can make the valve adjustment?
08.05.2020 17:53 # 7
samet206
[QUOTE = Turgay_66] there is also a bit of a twist on my engine, where can we make the valve setting? [/ QUOTE]
Normally, LPG vehicles have to make this setting more often, but my vehicle is losing the side of the grass while we pulled it out from gasoline fairing damage. -400 I hate good things. Do not ask for these works. The job needs to be done by a competent person. My teacher is important but I cannot leave where you can get it.
08.05.2020 17:53 # 8
Turgay_66
[QUOTE = samet206] [QUOTE = Turgay_66] there is also a little click on my engine where can we make the valve setting? [/ QUOTE]
[/ QUOTE] because I am afraid of the same thing, I do not want to go to industry.
08.05.2020 17:53 # 9
samet206
Exactly, teacher, we all have the same problems in part.
08.05.2020 17:53 # 10
samet206
samet206 2013-08-30 22:07:35
08.05.2020 17:53 # 11
DJ206XS
I have the same problem 2 3 days. I went to the industry today, I showed the master .. Valves loosened valve adjustment said. He said, "We can handle 30 to 40 liras." I made an appointment on Tuesday and I will go.
08.05.2020 17:53 # 12
samet206
[QUOTE = DJ206XS] I have the same problem 2 3 days. I went to the industry today, I showed the master .. Valves loosened valve adjustment said. He said, "We can handle 30 to 40 liras." I made an appointment for tuesday, i will go there ... [/ QUOTE]
Auspicious, it is cheap, there is no one doing less than 80, we would love between 80 and 100 without the service we went to constantly.
