What happened when I went to the service?
08.05.2020 14:59 # 1
marasov
Ağlama I went to the service, I made a check-up, I said, I said, "What if there is nothing?", they said that they made a cost of 2001 partner 1800 TL. They said that the clutch set is over. Then I went to the industry. Then I went to the industry.
08.05.2020 14:59 # 2
services are unfortunately so
08.05.2020 14:59 # 3
dikhoron
brother clutch is too high up .. is there any sound from the clutch balls .. run at idle, quietly in a silent place .. whirring sound is coming .. press clutches sound stops .. look at it .. master goes to this lesson bro .. in my opinion ..
08.05.2020 14:59 # 4
xMEGANx
don't believe in service. Do not forget that the services gather the masters who can not do the work outside. but he wants to change whatever he sees inside.
08.05.2020 14:59 # 5
dikhoron
I had an extreme problem because of the service. We apologize very much for what has been done, they said that we will pull the ears of those who are in Ankara. Let's see how it will be concluded.
08.05.2020 14:59 # 6
service means change ...
service means a lot of money ....
SERVICE MAY ME SUBSTISHING EVEN ...
service means THE END
08.05.2020 14:59 # 7
CHECK UP HOW DID YOU GIVE LIRA
08.05.2020 14:59 # 8
serkan24577
If you have a lot of money, you will go to the service, my sister is not even a sales consultant in the service.
08.05.2020 14:59 # 9
Your friends did not peel very well. These are the ways to earn money by selling and selling the piece and saying it is not finished.
08.05.2020 14:59 # 10
marasov
Wall They wanted 50 TL and I made carbon clear and they did not buy it for 60 TL.
08.05.2020 14:59 # 11
metin
[QUOTE = marasov] Ağlama I went to the service, I checked my car, I said, I said, "What if there is nothing?", they said that they made a cost of 2001 partner 1800 TL. They said that the clutch set was over. Then I went to the industry. I said to my friend's master.
If the clutch is missing, it is the simplest way to understand that it is over if you press the throttle but it does not go. By the way, are you satisfied with carbon clean?
08.05.2020 14:59 # 12
marasov
Ouch WANTED 50 TL
08.05.2020 14:59 # 13
erdal
My teacher recently changed the clutch set .. I asked the service, they said 385 lira prça 350 lira workmanship. 295 industry price. (material is the same material) I think it doesn't make sense to be dependent on the service ..
08.05.2020 14:59 # 14
furkan
I take refuge in ALLAHA from the authorized service
