What does wiper time role do? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 14:08 | # 1 |
| 08.05.2020 14:08 | # 2 |
No one understands this piece?
| 08.05.2020 14:08 | # 3 |
where are these roles in pejo 206
| 08.05.2020 14:08 | # 4 |
On BSI .. An electronics engineer who understands the job must check. For example, in the images below, the indicator lights relays are being changed. /P1010674.JPG "border =" 0 "/> & nbsp; & nbsp; < DIV> & nbsp; |
| 08.05.2020 14:08 | # 5 |
Thank you, I'm best, don't you know, do you have any information about what it does, do you think my wipers will work on their own in park and cruising?
| 08.05.2020 14:08 | # 6 |
[QUOTE = zaferpls] Thank you, I'm best, don't you know, do you have any information about what it does, do you think my wipers can work on their own in park and cruise? [/ QUOTE] DIV> & nbsp; Nothing is normal when parked. In Eco mode, the vehicle cuts off electricity completely and only the bsi stops at the standby position. I think relay the cable to the wiper motor until you find a good master. Feed the relay from a source of electricity when the ignition is turned on, such as lighter electricity. & Nbsp; Replace the fuse you removed. & Nbsp; Describe what I say to a good electrician. |
| 08.05.2020 14:08 | # 7 |
Would it be harm if I use it for 15 days? now the fuse is disconnected, of course, not only the wiper is connected to this fuse, the wipers, the signals, the car makes the center, then I can not use any of them
| 08.05.2020 14:08 | # 8 |
it makes more sense to replace the fuse and pull the battery cable
| 08.05.2020 14:08 | # 9 |
[QUOTE = zaferpls] It makes more sense to replace the fuse and unplug the battery [/ QUOTE] Do not disassemble the battery too much.
| 08.05.2020 14:08 | # 10 |
You're right, one electrician told me recently, one of your friends has changed the battery, but the car hasn't worked yet, but I unplugged the cable of the battery, but thankfully, nothing happened. .. DIV>
