What Does This Fault Code Say?
08.05.2020 15:21 # 1
frenzy
Hello friends. Some time ago, I connected the diagnostic device to my vehicle and checked the system as follows. 2 errors in ABS / brake section. Someone was concerned with deadlocking, I don't think of it now, I'll write later. The other one is `Permanent Fault. Brake was saying fluid level low, but today I looked at the brake fluid to the brim. Do you think this may cause this error?
08.05.2020 15:21 # 2
erdal_comak
Did you find a solution, my friend, I have the same trouble?
08.05.2020 15:21 # 3
Ali
I don't know if I said the solution is this, but what happened in a situation like this was this;
the discs have a plug to get the hydraulic air there, you open it then you press the brake, after a few presses, you get the hydraulic air, the problem is solved. However, I do not know if your problem will improve.
