What does the pipe in the photo do?
08.05.2020 15:08 # 1
tugrahan
Hello
I canceled my car's air filter box and replaced it with an open air filter
originally, a pipe from the engine near the calbulator inlet meets the large diameter pipe from the air filter box.
When the box was canceled, this pipe wasted. What does this pipe do?
I also paid attention to press the gas, that is, when the speed is increased, smoke comes from this pipe
Would there be any problem when idle?
or I have to put my little filter here
Why is it throwing smoke from here at high speed?
I also put in your pictures
08.05.2020 15:08 # 2
haruncoskun
you had to install the crank air filter on that empty pipe
08.05.2020 15:08 # 3
tugrahan
crank air filter haa
So what's my mood here?
But when I gas, it throws smoke from here
Pay attention to the 2nd picture, you will see the smoke
08.05.2020 15:08 # 4
haruncoskun
Was this hose not connected to the original filter bowl?
08.05.2020 15:08 # 5
tugrahan
yes from the original filter boiler and next to the carbore entering the calbulator
it is entering
08.05.2020 15:08 # 6
tugrabozan
If there is smoke, the engine is worn, does it burn the vehicle?
08.05.2020 15:08 # 7
tugrahan
no friend 1 gram fat does not decrease my vehicle
It's been 8 months and I look at the oil stick
stops at the same level.
the tugrah 2011-03-01 21:20:26
08.05.2020 15:08 # 8
tugrahan
Does anyone know where this smoke comes from?
08.05.2020 15:08 # 9
haruncoskun
if your circlips are worn
08.05.2020 15:08 # 10
tugrahan
Is circlip wear bad?
08.05.2020 15:08 # 11
haruncoskun
the most correct answer gives you engine repairman only we can guess
08.05.2020 15:08 # 12
tugrahan
Yes you are right
08.05.2020 15:08 # 13
peugeotefe
It is normal to have smoke, but it is useful to buy and install a crank filter there. The smoke coming from there is oil mist.
08.05.2020 15:08 # 14
tugrahan
thanks efe brother i was scared
obvious smoke comes after 5000 cycles.
Efe, I have a question, now I put on my open filter because the weather has improved.
lpg will be open air filter in a week I will wear lpg
do i have a problem
08.05.2020 15:08 # 15
LPG has nothing to do with the open filter. You can use it as you wish ...
it is also the pipe crank ventilation you have inserted. When the engine is hot, the vapor comes out. There are small filters for it as it is peeling, you have to wear them ...
08.05.2020 15:08 # 16
tugrahan
thanks everyone for the information
here is peugeottürkeyforum something like that
08.05.2020 15:08 # 17
aslanparcasi
Is it called crank ventilation, in other words, crankcase ventilation? You know, a pipe hangs under those old maguses and oil vapor comes out of it :)
08.05.2020 15:08 # 18
same thing yaaa :)) ha karter ha krank :))
where is the crank already standing just above the sump :)))
It should not hang out as this pipe stands alone. this condition makes the dog break. In our vehicles, crankcase ventilation depends on the air intake system of the vehicles. From there, it gives the oil vapor to the air sucked by the vehicle ... this causes the gas butterfly and the idle valve to break slightly in the oil vapor according to the connection type of the pipe ...
08.05.2020 15:08 # 19
When I went to the industry to replace the air filter the other day, I removed the top cover of the filter box (I know it as a carburetor). I kept the air where those hoses came. A measurement of nearly 1 tea glass (almost) of oil came out of the hose where it came from. Is this an indication of something bad?
08.05.2020 15:08 # 20
MustyRC
There's nothing to be afraid of, my brother, the steam coming out of the engine. It doesn't cause any problems to you. it is just taking and installing beer from small filters.
