WHAT DOES FRIENDS MEAN? BAKARMISNZ |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 207 | |
| 08.05.2020 18:43 | # 1 |
MY CAR PEUGEOT 207 1.4 GASOLINE WHEN I TURN THE CONTACT, THE ANATAR SIGN AND I EXPOSE THAT 1,100 KM GOING WHEN I RUN THE CAR .. WHAT IS
| 08.05.2020 18:43 | # 2 |
yawruaslan |
1000 km of maintenance time warns him
| 08.05.2020 18:43 | # 3 |
I already had the periodic maintenance done 1 month ago .. But not in service but in normal industry
| 08.05.2020 18:43 | # 4 |
yawruaslan |
When they do maintenance, they have forgotten to reset it, you will reset it yourself. I don't know exactly. Although it is not sure, do not leave the ignition key by pressing the button on the instrument panel when the ignition is off.
| 08.05.2020 18:43 | # 5 |
tmm thanks
| 08.05.2020 18:43 | # 6 |
Nothing to worry about. You are reset with the key on the panel that shows that the maintenance is coming. |
| 08.05.2020 18:43 | # 7 |
Efe-Pojo |
It has nothing to do with, but once I have economy mode active text on the screen, then it didn't come up again.
| 08.05.2020 18:43 | # 8 |
Alicilik |
The key is the sign of the maintenance period. Indicates km remaining for maintenance. As maintenance approaches, km decreases. To reset it, Turn on the ignition while your hand is holding the km reset bar, wait while counting down, wait after counting. The period will be reset. Economy mode, It is an application for protecting the battery of the vehicle. If the elements such as tape-light remain on while the vehicle is not running, the vehicle will protect the battery after a while and turn them off. |
| 08.05.2020 18:43 | # 9 |
Probably the same as 206, I had reset after the maintenance, but it started from 15 thousand.
| 08.05.2020 18:43 | # 10 |
ahmed206 |
I like this eco mode because I don't like the tape getting started before starting the car.
| 08.05.2020 18:43 | # 11 |
Press and hold the Km reset button, it will start counting down from 10. Release the button when it becomes 0. The key sign will go.
