What does 406 2.0 SV burn?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 17:41 # 1
yesil
Hello friends. I just joined you. I am Green from Ankara. My new model 1997 model 406 2.0 SV was burning 40 cents in the tube. I showed it to the veteran, said the injectors will change. I replaced gas filters with injectors. now it is burning 33 cents ... liter price of shell gas from 2.36 I went 60 km full with 20 lira gas ... so it travels 100 km with 14 lt gas ..
Is this fuel of 406 normal or is there any instability ... I am waiting for your help with your advice and comments ...
Thank you, days without accident ...
green 2013-06-12 11:21:03
08.05.2020 17:41 # 2
emre_akdag
I think it is ideal :)
08.05.2020 17:41 # 3
Barut
if 33 kr. If it burns, I think the 1.4 engine burns even 33 kr.
08.05.2020 17:41 # 4
error
We are talking about a 2 liter engine and a 1.6 ton vehicle, your consumption is very good.
08.05.2020 17:41 # 5
elsoberano
I think your fuel is normal
08.05.2020 17:41 # 6
samet206
I think we are talking about 2000 engines :)
08.05.2020 17:41 # 7
yesil
thank you for your comments. whoever I talked to, whichever master asked, they said they should have burned a maximum of 30 cents of 28 ... I wanted to ask my vehicle 33 cents closely ...
08.05.2020 17:41 # 8
yesil
Hello friends. & Nbsp;
yesterday I got 406 from shelld ... after fulledik, I traveled 25 km from the same station and reloaded from the same pump ... the result is disaster ... I made 25 km with 5.56 lt gas ... this is also It means & nbsp; 5.56l X 2.32 = 12.90 Kr. I made 25 km for 12.90 cents, so my 406 big lions burned 516 kr ...
this car puts a fig tree forest on my quarry ... injectors zero filters zero what is this ... I am 33 cents I was glad that it was burning. Let me finish this warehouse and see how many kilometers it will go ... If it continues to burn like this, I will say goodbye to 406 ...
08.05.2020 17:41 # 9
dream
Even a little burned.
08.05.2020 17:41 # 10
Mustafa-almanya
[QUOTE = Yesil] Hello friends. & Nbsp;
yesterday i completed 406 from shelld ... after fulledik, i traveled 25 km from the same station and reloaded from the same pump ... the result is disaster ... I made 25 km with 5.56 lt gas. ... this means that & nbsp; 5.56lt X 2.32 = 12.90 Kr. I made 25 km for 12.90 cents, so my 406 big lions burned 516 kr ...
this car puts a fig tree forest on my quarry ... injectors zero filters zero what is this ... I am 33 cents I was glad that it was burning. Let me finish this warehouse and see how many kilometers it will go ... if I keep burning like this I will say goodbye to 406 ... >
It is normal to burn 10 liters of gasoline per 100 kilometers on a liter basis, it is normal to decrease and show coma according to the traffic in progress.
& nbsp; & nbsp; I've often heard or read that scuba cars burn 10% to 15% more than liters of gasoline.
So 11 & nbsp; to 11 It is normal to burn 5 liters of LPG. However, it may be a little difficult to measure this, because it throws a pistol before every gasoline is full (every different gasoline is full). & Nbsp;
If I was in your place, fill the tube 100 km later and fill it with the same gas station and measure it.
regards
& nbsp; & nbsp;
08.05.2020 17:41 # 11
yesil
[QUOTE = Mustafa-germany] [QUOTE = green] Hello friends. yesterday i bought 406 from shelden ... i traveled 25 km after fulledik and reloaded from the same station from the same pump ... the result is disaster ... i have made 25 km road with 5.56 lt gas ... which means 5.56l X 2.32 = 12.90 Kr. I made 25 km for 12.90 cents, so my 406 big lions burned 516 kr ... this car sewed a fig tree forest to my quarry ... injectors zero filters zero what it is ... I was glad that it was burning 33 cents. let me finish this tank, let's see how many kilometers will go ... if I continue to burn like this, I will say goodbye to 406 ... [/ QUOTE] It is normal to burn 10 liters of gasoline in 100 kilometers per liter basis, it is normal to decrease and show progress according to the traffic you drive. I have often heard or read that scuba cars burn 10% to 15% more than liter gasoline, so it is normal to burn 11 to 11.5 liters of LPG. However, it can be a little difficult to measure it, because it throws a pistol at every gasoline before the tank runs out (at a different level in each gasoline). If I was in your place, fill the tube 100 km later, fill it again with the same gasoline and say so. Regards. If the 25 km road burns 12.90 TL, it means 51 kuruş per km ... as you said, I filled the same pump with the same gasoline as you said ... I cleaned the throat butterfly yesterday, I will replace the spark plugs as soon as possible and I will have the tube adjusted again ... I will sell the car despite maintenance ... thank you ....
08.05.2020 17:41 # 12
yesil
Hello to everyone. friends cleaned the throat butterfly of my vehicle ... it is said that the spark plugs do not need to change ... now it is 33 liters per km while the gas lt price is 2.32 tl. inner city. div> how do you think this value is?
08.05.2020 17:41 # 13
yesil
veee spark plugs, engine oil, oil filter, air filter, polem filter, new gas injector set in the injectors ... Besides, with the price of 2.35 TL shell pump, it burns 8 * 2.35 = 18.8 TL per km.
08.05.2020 17:41 # 14
mustafa ogretmen
Hello friends ... I just joined you & nbsp; I bought a white lion in the 2001 model 2.0 Sv & nbsp; model. / div>
My measurements are as follows .. I dropped 25 liters of gas from the same pump and in both of my attempts, I used a little more in the city than 100 km in the long road average. & nbsp; I have consumed gas ... Gas .3.10 pounds ... how do you think this result?
08.05.2020 17:41 # 15
yusuf2757
Friends, I never approve of bad breathing as a Peugeot patient. I have the 1998 model Peugeot 306 XR 1.8cc 16 valves and 1997 peugeot 406 SV that I use right now. Make sure that my 406 car does not exceed 27/28 kuruş. I get the gas at 2.79.
08.05.2020 17:41 # 16
my vehicle does not exceed 2000 model 406 sv inner city 25-26 kurus. drops up to 20 cents on the long road.
08.05.2020 17:41 # 17
cngz
sa, I found two of them, one of them is automatic (st) and the other is (sv) manual. This fuel is going to be stuck in my head.
08.05.2020 17:41 # 18
cngz
my friends and brothers who are actively using this tool or who have information please write.
08.05.2020 17:41 # 19
33 krş put it on my brother brother 2.0 engine car nothing to think is perfectly normal
08.05.2020 17:41 # 20
cngz
If you burn 33 35 kurus in the city, I am willing to consume fuel consumption.
Page : / 2
