What did I start to burn a little :)
08.05.2020 18:31 # 1
cool
Friends 206, I usually buy 50 tl of gasoline, so far I could go a maximum of 130 km.
Recently, I always bought 50tl of gasoline from the gasoline I bought and reset the km. The vehicle has gone 420km, the warehouse is still not understood.
08.05.2020 18:31 # 2
Bugra
sometimes, when I take the fuel from time to time, the vehicle does not hold much values, and I often lived in different vehicles. the pointer can sometimes mislead. The amount of fuel that can vary from pump to pump
08.05.2020 18:31 # 3
herry
If you think about it, do the full pump, do it 100 km later, make it full from the same gasoline, pump it, you will know how many money it burns. this is the cleanest account. If you perform the same operation once more at 100km, you will find the clearest figure.
08.05.2020 18:31 # 4
yawruaslan
If you think of [QUOTE = herry] too much, do the full pump, make it full from the same gasoline after 100 km, pump it, you will know how many money is burning. this is the cleanest account. If you perform the same operation once more at 100km, you will find the clearest figure.
I always do what you say, the first 100 km is 60 kurus in the first 100 km, the other 35 the other 40 :)
08.05.2020 18:31 # 5
herry
If you think of [QUOTE = yawruaslan] [QUOTE = herry] too much, do the full pump pump, 100 km later, make the pump full from the same gasoline, you will see how many money is burning. this is the cleanest account. If you perform the same operation once more at 100km, you will find the clearest figure.
I always do what you say, the first 100 km is 60 cents in the first 100 km, the other 35 and the other 40 :) [/ QUOTE]
then you're going to get an average, you're probably burning 45 cents Wink
08.05.2020 18:31 # 6
yawruaslan
[QUOTE = herry] [QUOTE = yawruaslan] [QUOTE = herry] If you think of it, do the full pump, do it again from the same gasoline after 100 km, you will see how much money is burning. this is the cleanest account. If you perform the same operation once more at 100km, you will find the clearest figure.
when I change the tires it drops even more I use 195/45/15
08.05.2020 18:31 # 7
serkomser
There may be many reasons for this.
The indicator may have malfunctioned,
Usage may be different,
The fuel station may have improved quality,
The vehicle may have dropped the dirt on time,
etc. etc.
Sometimes my fuel values change. Make sure it can even be psychological :)
I wish you a pleasant ride.
