What could be the reason for exhaust blowing
08.05.2020 20:44 # 1
AhmetSehzade
Friends I have a 306 1.6 platinium 2001 car, running late, and when the car is cold, what might be the reason for exhaust blasting?
There is a lot more when gas passes?
What could be the reasons for fluctuations in the tachometer?
Which brand will I replace the spark plugs and how should I buy them?
08.05.2020 20:44 # 2
akk0212
usually ignites, check the spark plug and wires
08.05.2020 20:44 # 3
As our friend says, spark plugs and cables are usually caused.
08.05.2020 20:44 # 4
x571
[QUOTE = AhmetSehzade] Friends I have a 306 1.6 platinium 2001 model car running late and what could be the reason why it blows up exhaust when the car is cold.
ignition shortage. Check spark plug and coil. use original parts when replacing. it's not a very tricky problem. It will be alright.
08.05.2020 20:44 # 5
AhmetSehzade
Which spark plug is suitable and which should I buy?
Gas + Gas
08.05.2020 20:44 # 6
AhmetSehzade
[QUOTE = sonerkyl] As our friend says, it usually causes spark plugs and cables. [/ QUOTE]
my gasoline + gas vehicle 1.6 platinium 2001 which spark plug and coil should i buy, how and where to buy, can you help me?
08.05.2020 20:44 # 7
ismailkaya
I know that spark plugs have an adjustment in important gas vehicles.
08.05.2020 20:44 # 8
[QUOTE = AhmetSehzade] [QUOTE = sonerkyl] As our friend says, it usually causes spark plugs and cables. [/ QUOTE]
