what can i do for fever
08.05.2020 18:43 # 1
gpa98106
Hello friends. My vehicle is 106 quicksilver. The weather is hot and the temperature of the vehicles is increasing. I am having a problem because there is no temperature indicator in my vehicle. When I went to the last maintenance, I saw that the fan of my vehicle opened at 100-101 degrees. What do you think I can do for this? I should change my fan sender, or should I do the system that opens the fan manually.
NOTE: Some friends are wearing tofaş sender. Thanks in advance to those who did not write an effective answer.
08.05.2020 18:43 # 2
mgulcan
As far as I know, peugeot's turn on the fan after 100 degrees.
08.05.2020 18:43 # 3
madblueblacksea
[QUOTE = mgulcan] To my knowledge, peutos turn on the fan after 100 degrees. [/ QUOTE]
My teacher opens it in 96, 100 is a bit too much. Do not say what happens at 4 degrees water boils at 4 degrees :)
08.05.2020 18:43 # 4
mgulcan
I told you wrong, I told you wrong, I mean it is opening late compared to other tools.
QUOTE = madblueblacksea] [QUOTE = mgulcan] To my knowledge, peutos turn on the fan after 100 degrees. [/ QUOTE]
My teacher opens it in 96, 100 is a bit too much. Do not say what happens at 4 degrees, 4 degrees of water boils:) [/ QUOTE]
08.05.2020 18:43 # 5
ank06sf940
my 206 is the original sender 98 c but I put the winter sender of tofaş turns on the fan at 92 degrees, the indicator stays at 92 c since the original in the thermostat opens at 89.
the original customer and the indicator remained between 95 and 98 c, but the thermostat will remain fixed if you do not enter the traffic between 70 and 80 in summer.
