What can be done to reduce fuel? |
| 08.05.2020 18:31 | # 1 |
1: oil changed 2: oil filter changed 3; spark plugs changed 4: air filter changed 5: lpg setting is done What more can be done? |
| 08.05.2020 18:31 | # 2 |
if there is no problem with the vehicle, there are 2 main factors affecting the fuel 1- Driver's usage style and traffic density 2- fuel you get in your vehicle I recommend you to go over these two .. If I have 100 km with the gas I bought from Moil when I have a LPG vehicle, I was doing 50 km with the Aygaz I bought from the opet, and on the same route, in the same conditions.
| 08.05.2020 18:31 | # 3 |
Use it at low speeds, give the gas constant and search. its performance increases when it is lighter I don't know if it will affect fuel
| 08.05.2020 18:31 | # 4 |
Pressing the gas The status of the tires is very important, Unnecessary load in your vehicle (Subwofer, Spare wheel, Bag manta etc.), Do not take sudden departures, Skating, If you are going to wait longer than 20 seconds in the lights, hit the vehicle and start it 5 seconds before, Choose the roads that you will not pause, not the shortcut Use quality fuel (avoid cheap fuel, such as cart curt petrol etc.) Passing 85 KM / S on the long road. Try to climb the slopes with high gear but don't force the vehicle Set idle below 100 Avoid filter and oil maintenance and avoid cheap goods, be your original preference. Modifying the engine (using performance enhancing products) If you are traveling faster than 40 km / h, opening a window Have a chassis checked. Use compatible wheel size and tire. If you say my car is still very close, you will be in the stingy category, but if a friend burns the car 140 cents, how do I still reduce it .. Hey God.
| 08.05.2020 18:31 | # 5 |
[QUOTE = Alper134] if there is no problem with the vehicle, there are 2 main factors affecting the fuel 1- Driver's usage style and traffic density 2- fuel you get in your vehicle I recommend you to go over these two .. If I have 100 km with the gas I bought from Moil when I have a LPG vehicle, I was doing 50 km with the Aygaz I bought from the opet, and on the same route, in the same conditions. [/ QUOTE] ![]() Except the brand, it is important to the dealer you bought. I was constantly buying from milangas, but the way I did was, for example, I was doing 70 km with 30 lira. But in another place, I came across a milangaz dealer, I bought it, 30 lira fuel, I tried 81 km road, I bought 3-4 more times, I did not change 80-75-85 km road, friends are at the dealer ...
| 08.05.2020 18:31 | # 6 |
outlaw |
[QUOTE = eurest] Press the gas The status of the tires is very important, Unnecessary load in your vehicle (Subwofer, Spare wheel, Bag manta etc.), Do not take sudden departures, Skating, If you are going to wait longer than 20 seconds in the lights, hit the vehicle and start it 5 seconds before, Choose the roads that you will not pause, not the shortcut Use quality fuel (avoid cheap fuel, such as cart curt petrol etc.) Passing 85 KM / S on the long road. Try to climb the slopes with high gear but don't force the vehicle Set idle below 100 Avoid filter and oil maintenance and avoid cheap goods, be your original preference. Modifying the engine (using performance enhancing products) If you are traveling faster than 40 km / h, opening a window Have a chassis checked. Use compatible wheel size and tire. If you say my car is still very close, you will be in the stingy category, but if a friend burns the car 140 cents, how do I still reduce it .. Hey God. [/ QUOTE] |
| 08.05.2020 18:31 | # 7 |
| 08.05.2020 18:31 | # 8 |
[QUOTE = outlaw] [QUOTE = eurest] Press the gas The status of the tires is very important, Unnecessary load in your vehicle (Subwofer, Spare wheel, Bag manta etc.), Do not take sudden departures, Skating, If you are going to wait longer than 20 seconds in the lights, hit the vehicle and start it 5 seconds before, Choose the roads that you will not pause, not the shortcut Use quality fuel (avoid cheap fuel, such as cart curt petrol etc.) Passing 85 KM / S on the long road. Try to climb the slopes with high gear but don't force the vehicle Set idle below 100 Avoid filter and oil maintenance and avoid cheap goods, be your original preference. Modifying the engine (using performance enhancing products) If you are traveling faster than 40 km / h, opening a window Have a chassis checked. Use compatible wheel size and tire. If you say my car is still very close, you will be in the stingy category, but if a friend burns the car 140 cents, how do I still reduce it .. Hey God. [/ QUOTE] Let +106 come
| 08.05.2020 18:31 | # 9 |
Thank you friends. who want to give other information.
| 08.05.2020 18:31 | # 10 |
candanxyz |
you can have the timing control checked, if you jump on a cent, it doesn't matter in use, but the car burns more than usual. Because some masters change it carelessly. |
| 08.05.2020 18:31 | # 11 |
Listen to classical music, it calms down. So you don't hit the gas.
| 08.05.2020 18:31 | # 12 |
look at the knock sensor. If it is broken, the car will start burning a lot. My vehicle is Peugeot 307 1.4 hdi. It burns a lot. I'll take care of it.
