What are the Situations You Cannot Pass Vehicle Inspection?
08.05.2020 18:05 # 1
mazda3
Vehicle Failures That You Cannot Pass Through Vehicle Inspection? What? What are your vehicle's often failing parts?
08.05.2020 18:05 # 2
ahmed206
I could not pass with the 2000 model volvo s40 because I did not have a fire tube ...
On the same day, the 2010 model Honda Civic did not pass because the distribution of the rear brakes was unstable.
08.05.2020 18:05 # 3
mev347
I could not go because of the brake system and steering lock
08.05.2020 18:05 # 4
okan77
106 quixilver rear brake deflection, I burned the repetition again ... I gave 2 times inspection money ... Then the man is chronically already because the vehicle is light, the back right corner remains light and deviates ... Wouldn't I say ... I was going to man the year 2008 ....
08.05.2020 18:05 # 5
_ali_
I was left with the rear brake this summer, they had published statistics, and the vehicles are usually left from the brake system. In industry, the same test is carried out on 20-TL in the test device, it is absolutely necessary to have it examined without going to the examination.
08.05.2020 18:05 # 6
The brake deviation should be less than 30%. It is the subject I appreciate with the headlight adjustment. Think man is braking at high speed. It hits the vehicle on the right or left just because it brakes. This type of accident is prevented as it is corrected due to the inspection. dogan106 2013-11-22 11:42:50
08.05.2020 18:05 # 7
okan77
[QUOTE = dogan106] Brake deviation should be less than 30%. It is the subject I appreciate with the headlight adjustment. Think man is braking at high speed. It hits the vehicle on the right or left just because it brakes. This type of accident is prevented because it is corrected due to the inspection. [/ QUOTE]
I appreciated it, because the brake deflection holds less than the other one ... The master looked at it and made the adjustment from the drum ... I also received the breath in TÜV ... I asked the staff to do it, I said that my master made adjustments ... .... The first year of 2008, the first year of TÜVTÜRK, my first departure has been madur ... Anyway he took the vehicle in ... I look at the other exit, he said he signed the signature. Conclusion, there is a deviation. I said I had it made, we made a comparison, yes, there is something done, but it has not happened ... I took the breath with the master ... In the end, the process is being done, but in those years, the brake tester is not in any industry ... I made the subaru Yerkada in the masque for 20 dollars. Then I was shaved in the drum lathe with my master, the pads changed, the brake centers changed and the hydraulic changed ... Then again Subaru ground test no positive deviation ... At the same time ... I went through the examination at a time .. Then I asked why I said it was chronic ... He said the comment I made above ... I can never forget ...
08.05.2020 18:05 # 8
volkanC2
No such situation Cool It's a joke since I was left with the left rod shaft gap, but I passed it :) My friend was writing 4 seats in the license but the car remained because it was 5 seats, they gave paper and corrected it from the traffic.
08.05.2020 18:05 # 9
fatihgg
[QUOTE = volkanC2] Nothing like that Cool Since the joke, I was left with the left rod shaft gap, but I passed it :) My friend was writing 4 seats on the license, but the car remained because it was 5 seats, they gave them paper and they corrected it from the traffic. [/ QUOTE]
I had the same situation last year because of this seat :)
08.05.2020 18:05 # 10
gogly35
We couldn't pass because of xenons, there was no problem Smile gogly35 2013-11-22 17:25:29
08.05.2020 18:05 # 11
ahmed206
Some things should really matter that they insist, for example brakes, xenon ...
Sometimes they overestimate the seat ...
08.05.2020 18:05 # 12
206x-line
the ceiling covering, the American park, also looked at the clarity of the brake lights, did not pass through them
08.05.2020 18:05 # 13
it's a bit of a discretion for me to get past it.
maverick 2013-11-23 00:34:23
08.05.2020 18:05 # 14
samet206
I was left from the brake deflection.
08.05.2020 18:05 # 15
Mustafa-almanya
Ford fiesta 1990: He couldn't get through the Rot problem.
Ford dating 1991: It was not late because it was six bruises.
Bmw 318 1994: Because it is very close to the ground, the numbers of Eibach springs are not read, for the headlight muscles, for the sports pedals, because the exhaust is too loud, for the KN air filter, for the rear spoiler, for the wide and low-profile tires .
Audi A4 1995: Cracked in ten windows, 1.5 cm cracked in the rear stop (I say without exaggeration), could not pass because of the ten brakes.
Alfa 156 2000: Front Brakes could not be overtaken due to Catlak fog light and ABS error.
Citröen Xantia 1997: Because of the ABS error and the profile could not pass for less tire .
Opel vectra GTS 2004: The Rear Brakes and Tire profiles were not overcrowded.
Peugeot 407 SW 2005: The rear brakes and the glow plug could not go through the fault.
Clio 2002: Inspection of this is the new bar.
08.05.2020 18:05 # 16
crazyegal
I have the 2006 model 307. They issued a price around TL. While the vehicle is in this state, I would appreciate if the idea of helping me pass the examination.
08.05.2020 18:05 # 17
Mustafa-almanya
[QUOTE = crazyegal] I have the 2006 model 307. I will be examined in December. My car is petrol + lpg but my car stops at lpg. They said it had to change and they raised around 750 TL. While the vehicle is in this state, I would appreciate if the idea of helping me pass the examination.
Even if the factory is closed, I think that another brand is using the same brain. The brand logos may be different, but the brain is the same (you need to do a good search on the internet), and also do not ignore the chance to come out. Don't hurry up to 750 lira ...
08.05.2020 18:05 # 18
terzuu
Although the 2005 model brother hundai gets the vehicle twice before the exam, this year the color of the vehicle was purple in orhanlı Istanbul before the sacrifice feast in 2013, and it could not pass by saying it was a heavy defect. The machine shows a purple color, it says blue-purple lilac on the license. but unfortunately he could not pass.
Anyway, we said we should not drive the hill. We contacted the lady on the phone, found the documents of the vehicle and sent it. it wrote blue (lilac) purple. purple at the end. we have changed the license tuv rep. serv. We talked to Orhanli tv manager asked us to see the manager, we found the man did not say, "What is this car?" "Purple". Anyway, we used tuv. Those who have a metallic car color, this kind of tricks. our brother gets in color in the daytime blue evening purple night in lilac color, so he wrote three colors in the license.
