What are the maintenance to be done 206 I just bought? |
| 08.05.2020 18:12 | # 1 |
I changed the filters and oil of my new car (206 1.4 Hdi), so the classic 10,000 maintenance is ok. What kind of maintenance should I have in the following processes, especially to reduce fuel consumption? How much will these treatments cost me? Also, are there any masters or services on the ikitelli side that you can recommend that will not be material and moral? Thanks in advance ..
| 08.05.2020 18:12 | # 2 |
Check the tires clearly and look at their spark plugs. these are for saving. |
| 08.05.2020 18:12 | # 3 |
Alicilik |
Check the [QUOTE = herry] tires clearly, and they will look at their spark plugs. these are for saving. [/ QUOTE] Let them not look at the spark plugs car diesel. injector cleaning and soot cleaning can be done for the catalyst. Costs are between 50-200 If you are on average 15000 km (valid time for euro4s but you said 10 thousand), Routine oil and oil filter replacement -Air filter -Pollen filter Apart from that, the two maintenance centers will be able to replace diesel filter every 30 thousand km Have the gearbox oil checked. Use a fln injector cleaner every 30 thousand, although not every maintenance. |
| 08.05.2020 18:12 | # 4 |
[QUOTE = Buying] Check the [QUOTE = herry] tires clearly, and look at their spark plugs. these are for saving. [/ QUOTE] Let them not look at the spark plugs car diesel. injector cleaning and soot cleaning can be done for the catalyst. Costs are between 50-200 If you are on average 15000 km (valid time for euro4s but you said 10 thousand), Routine oil and oil filter replacement -Air filter -Pollen filter Apart from that, the two maintenance centers will be able to replace diesel filter every 30 thousand km Have the gearbox oil checked. Use a fln injector cleaner every 30 thousand, although not every maintenance. [/ QUOTE] like a doctor, maaallah, wrote the recipe ![]() |
| 08.05.2020 18:12 | # 5 |
Check the [QUOTE = herry] [QUOTE = Buyer] tires [QUOTE = herry] clearly, and look at their spark plugs. these are for saving. [/ QUOTE] Let them not look at the spark plugs car diesel. injector cleaning and soot cleaning can be done for the catalyst. Costs are between 50-200 If you are on average 15000 km (valid time for euro4s but you said 10 thousand), Routine oil and oil filter replacement -Air filter -Pollen filter Apart from that, the two maintenance centers will be able to replace diesel filter every 30 thousand km Have the gearbox oil checked. Use a fln injector cleaner every 30 thousand, although not every maintenance. [/ QUOTE] like a doctor, maaallah, wrote the recipe ![]() [/ QUOTE] Thank you. The information was very useful for me ... I have one more question What tools does euro4 cover?
| 08.05.2020 18:12 | # 6 |
Alicilik |
The information was wrong and vice versa ![]() |
| 08.05.2020 18:12 | # 7 |
Ok thanks my car 2007. Then my maintenance continues to 10,000 km.
| 08.05.2020 18:12 | # 8 |
Alicilik |
[QUOTE = ferhattasdemir] Okay, thank you, my car is 2007. My maintenance continues to 10,000 km then. [/ QUOTE] I know your vehicle is Euro4 km maintenance process is 15000. the above information was reversed |
| 08.05.2020 18:12 | # 9 |
[QUOTE = Receiving] [QUOTE = ferhattasdemir] Okay, thank you, my vehicle is 2007. My maintenance continues to 10,000 km then. [/ QUOTE] I know your vehicle is Euro4 km maintenance process is 15000. the above information was reversed [/ QUOTE] Thanks again for your interest and information.
