What are the front kits of the vehicle |
| 08.05.2020 18:48 | # 1 |
| 08.05.2020 18:48 | # 2 |
Things such as swings, tie rods, tie rod, suspension rod, wheel balls usually form the front set, axle, shock absorber etc. parts enter the hitch and I can make a guess according to them if you write the situation in your own by not counting them one by one. |
| 08.05.2020 18:48 | # 3 |
It is not understood by opening the bonnet, you should occasionally turn off the music on quiet and bumpy roads and listen to the sounds coming.
| 08.05.2020 18:48 | # 4 |
For now, there is no problem in my car, there is no problem in the bumps and bumps, I do not slow down so much, so I started to suspect that it was not a problem because I was nothing.
