wetness on the driver's side
08.05.2020 19:31 # 1
salihbrc
Hi salihbrc 2016-02-20 15:52:56
08.05.2020 19:31 # 2
crazysado
May be from the heater core, check your chronic problem skates in pejo and observe the spare water canister. Is there a decrease in water?
08.05.2020 19:31 # 3
samet206
Check the radiator water urgently. The vehicle can overheat. The classic antifreeze is probably missing the honeycomb if you put a new antifreeze in the vehicle.
08.05.2020 19:31 # 4
just as I agree with friends, if it is not due to external factors, it is from the heating comb. I made that problem myself.
08.05.2020 19:31 # 5
salihbrc
Thank you all. I bought the vehicle two weeks ago. and as soon as I took care of it. it was placed in antifreeze, of course, as you probably said. I do not have much chance to use it on weekdays. I will check the vehicle immediately in the evening. We are in the industry on Saturday. We cleared the butterfly, and it is still going on. thanks again. salihbrc 2015-11-26 09:12:06
08.05.2020 19:31 # 6
If you say that if you say they are going to remove the full breast instead of the right water drain heater petegid, you can be removed without dismounting the chest. There is a joint there is a single bolt out of the factory, but there are two more places. First of all, you supply two more. I am sitting on the Xinjiang side, if you are on those sides, I can help you and we will meet you. sonerkyl 2015-11-26 09:17:53
08.05.2020 19:31 # 7
salihbrc
salihbrc 2016-02-20 15:54:30
08.05.2020 19:31 # 8
I would ask my teacher for Saturday infallible probably I'll go to the unfailing industrial valve timing.
08.05.2020 19:31 # 9
salihbrc
I will be in 88, I will contact you according to the situation. See you.
08.05.2020 19:31 # 10
Factors Affecting Idling in the LPG System 1- If LPG injectors are faulty, it will cause shaking in the vehicle. 2- If the LPG setting is broken, there is a problem of idling every 30,000 km. 3- If the LPG brain is heated late for various reasons or if the transition temperature to gas is set low, there is an idle problem when the engine is cold. 4- If the injector nozzles are small or large 5- The LPG brain, that is, if the regulator is faulty, it will not send regular amount of gas to the injectors because it will change the pressure continuously, and this will cause an idle problem in the vehicle. 7- In rare cases, if the LPG ecu is defective, the injector times will be confused or idling problem occurs because it sends gasoline while working in LPG. 8- If the gas cutter is too clogged in the inner filter, it affects idling and traction. The gas cutter inner filter should change between 30 and 50,000 km. 9- One of the factors affecting the inline system idle setting arises from the mounting of the injector nozzles in the long distance. Reasons Affecting Idling From Engine System 1- If throat butterfly is dirty and adaptation adjustment is not done, it affects idling. 2- If the vehicle's charging dynamo does not perform its duty fully, that is, it affects idling due to low charging. 3- If there is a malfunction in the idle engine, it causes irregular operation at idle in both gas and gas. 4- If the air filter is blocked, the motor will not work to stabilize because it will receive irregular air. 5- If the ignition system is malfunctioning, the sequential system creates an idle problem. The subject is an excerpt from a site that sells lpg spare parts. sonerkyl2015-11-26 12:13:18
08.05.2020 19:31 # 11
salihbrc
It is fine now as we solved the self-gasing by changing the idle valve and the sensor.
salihbrc 2016-02-20 15:55:28
