Welcome and Goodbye Headlights :)
08.05.2020 19:15 # 1
blntctn
Hello friends again,
I wanted to thank you again before writing my problem for almost all my questions cewap :)
friends, actually my problem is not a problem, I wanted a war recently, I thought that there was no solution, I could not find the issue anyway. When you lock or open the vehicle with the remote control, the issue of the headlights that light up for 10 seconds is now burning, the 4's are burning, the electrics can be pulled from the 4's, and the setting can be applied to the headlights. What should I do?
08.05.2020 19:15 # 2
outlaw
It is called follow me home module. You don't need to do anything.
08.05.2020 19:15 # 3
KILIC
[QUOTE = blntctn] Hello guys,
Hodja, you can make him burn while locking the vehicle. Make the selector switch without removing the key from the ignition, remove the key, lock the doors, the headlights are on for approximately 45 seconds, then go out. However, in order to burn when the doors open, you need a module as your friend said.
08.05.2020 19:15 # 4
blntctn
thanks guys are ok :)
08.05.2020 19:15 # 5
ERDINC
I also got the follow me module you mentioned 2 years ago and it still goes on sale.
