Weakness in the first starter
08.05.2020 21:30 # 1
x571
Hi
The vehicle had not run for about 1.5 to 2 weeks. On top of that, the vehicle worked hard with a very weak starter sound, such as the first thing. The battery is about 4 years old. Valiant or happy brand. Why might the vehicle have done this? What are the controls to be taken and the measures to be taken?
08.05.2020 21:30 # 2
talip206
The battery is now completing its life. I think you should run the battery once a week for at least 10 15 minutes.
08.05.2020 21:30 # 3
x571
[QUOTE = talip206] The battery is now completing its life. I think you can recharge the battery at least 10 15 minutes a week. [/ QUOTE]
This battery died very quickly. I replaced the original battery in 2016.
We used to put water or something, is there anything to do?
which brand should you buy? everyone complains about a brand.
What can be done to prolong the life of the battery? like maintenance?
x571 2020-04-07 10:19:03
08.05.2020 21:30 # 4
x571
the subject is up to date. Searching for friends with knowledge about the battery.
02.10.2020 14:32 # 5
dfiratd
My battery friend, the same thing happened to me yesterday evening. Tomorrow we will take the 12 v 60 amp battery and wear it. Symptoms are like this, the starter is cozier, it gets a hard starter, the sound period becomes rare and one day I know out. There is a hole in the glass hole is the observation point. If it is green, the battery is full, if it turns black, it is finished. Batteries immediately detect whether the charger is working with ammeter and voltmeter. Let me pass as information because it happened to me. When I took my foot off the brake in my Renault automatic diesel vehicle, it was normally the act of moving forward or moving slowly. The automatic transmission is ultimately in principle such an expected movement. However, whatever happened, he was not performing this action for a period of time. it was moving when the gas was pressed. At that time, I had to change the battery, it was over and in this problem I mentioned, the battery was cut off when I changed. I mean, the battery weakness can even cause movement problems in automatic vehicles.
02.10.2020 14:49 # 6
ismailkaya
I saw that if the vehicle runs tense, the battery goes for 5-6-7 years, if the vehicle is working for 4-5 years, the battery loses its feature in 2-3-4 years. I say change, I always say use our local brand so that our money remains in our country.
06.10.2020 18:51 # 7
x571
[QUOTE = ismailkaya] I saw that if the vehicle works tense, the battery goes for 5-6-7 years, if the vehicle is working intermittently for 4-5 years, the battery loses its feature in 2-3-4 years. I say change, I always say, use our local brand so that our money stays in our country [/ QUOTE]. Well let's see what we will do this winter. difficult baby is coming this winter. to the spring or the next winter.
