We were exhausted
08.05.2020 21:18 # 1
onair69
Hello friends,
I am the first owner of the 2008 model 207 1.6 petrol automatic, the values I took to the exhaust inspection were very high, there was no problem when I had it last time. When we connect it to the computer, 2 3 problems came out, the master said he didn't speak very confident and he got to look at it. I read the comments that the catalytic converter may be clogged because of the low speed since the car is generally urban and automatic on the Internet. even the staff doing the exhaust inspection had said that the high-speed 20 min use opens.
Did you have such a problem, what would you suggest? thanks in advance.
08.05.2020 21:18 # 2
x571
You can use it at high speed and try it. If he says he needs to open and look, he will definitely whistle. It would be better if you had the inspection done at the private examination place, not at the tuv. If possible, make the new examination private. How are the city buses, pickups, hawks passing by the black smoke? When he came to the citizen, he immediately left.
08.05.2020 21:18 # 3
onair69
I used it at high speed on the highway and went to the special exhaust inspection directly in maslak industry, the result is the same. I think the converter will change 🤔 🙁
Is there any exhauster who wears a safety converter in Maslak industry?
08.05.2020 21:18 # 4
x571
[QUOTE = onair69] I used it at high speed on the highway and went to the special exhaust inspection directly in the maslak industry, the result is the same. I think the converter will change 🤔 🙁
Are there any exhausters in the Maslak industry who wear safety converters?
What a ridiculous private thing. Give money and stay away from the examination. Talk before you make it, you will have an agreement and let me do it .. & nbsp; Do not deal with safety convector or something. Reviews
08.05.2020 21:18 # 5
pusutr
I read somewhere on the Internet. Maybe it will work for you.
Tell me there is a situation
to our exhausters, vehicles that were all in place and without any deficiencies or inserted parts were introduced in 2-3 exhaust systems.
Have the car set up from the exhaust inspection, they said they were too rich
standard for Mercedes-Benz compressor coats vs standard
we put 3-4 liters of ethanol in the tank
After 15-20 minutes, we went to the examination again.
and the post went perfectly
If you have faith, if your car is giving as a rich wife, put ethanol and go through a direct exhaust examination.
08.05.2020 21:18 # 6
Professor würt injector cleaner, use a cycle of 100-150 TL on top of the gasoline. If the catalyst is overfilled, you will have to make a change.
08.05.2020 21:18 # 7
onair69
As you said, I think there is a lot of money stuck with the catalyst filled 🙄
onair69 2019-09-04 14:41:11
08.05.2020 21:18 # 8
onair69
[QUOTE = sonerkyl] My teacher würt injector cleaner use a cycle of 100-150 TL on the forehead. If the catalyst is overfilled, you will have to make a change.
08.05.2020 21:18 # 9
Since your engine is with the VTI coach catalyst outlet manifold, it will be expensive, unfortunately, it will cost around 2500-3000 TL. In addition, if you buy the piece in cash, you can get a nice discount or you can buy it in installments with a card.
08.05.2020 21:18 # 10
onair69
[QUOTE = sonerkyl] Since your engine is with the VTI teacher catalyst outlet manifold, it will be quite expensive, unfortunately it will cost around 2500-3000 TL. In addition, if you buy the piece in cash, you can get a nice discount or you can buy it with a card in installments. [/ QUOTE]
Unfortunately, as you say, is there a place you recommend for the piece
08.05.2020 21:18 # 11
[QUOTE = onair69] [QUOTE = sonerkyl] will cost around 2500-3000 TL, unfortunately, because your engine vti teacher is with catalyst outlet manifold. In addition, if you buy the piece in cash, you can get a nice discount or you can buy it with a card in installments. [/ QUOTE]
You can ask here https://www.otoyedekmarket.com/ brother.
