we thought brain failure !! SOLVED !!
08.05.2020 18:36 # 1
popeyes
I hope it helps you too.
Hi guys, as many of you know, I've been dealing with vehicle brain malfunction for a long time.
Finally, as a result of my follow-ups, I realized that the rainwater leaked from the ventilation holes on the hood and dripped onto the sockets of the vehicle's brain and had a chassis there. I have made this myself a temporary solution for now,
can I evaluate if there are those with better ideas?
Meanwhile, I have nothing left for my vehicle. I asked so many masters that they said the brain was malfunctioning because they were all fraudulent. Even though the guys made the car brain, they are not clear in anything, I can not find a word to tell them.
"I have never lost my faith. " If the brain was malfunctioning, it would always fail. "
consequently, it is not necessary to believe every person who says that it is necessary to chase the brain malfunctions to the end !!!
thanks everyone!!!
08.05.2020 18:36 # 2
Serkan
Get well, you jumped cheap.
08.05.2020 18:36 # 3
madblueblacksea
Firstly, get well soon. Not because you found the problem, but because you got rid of the repairers :) As far as I get from the pictures, there is a collapse in the gutter that passes over the brain and it gives the water inside. You need a hood for this topic. I think you need to solve the workaround in a short time because the brain cannot breathe now. There is no atmospheric pressure and no air circulation required for cooling. Black plastic pressure sensor, like a button in the middle of the brain.
08.05.2020 18:36 # 4
popeyes
[QUOTE = madblueblacksea] First, get past. Not because you found the problem, but because you got rid of the repairers :) As far as I get from the pictures, there is a collapse in the gutter that passes over the brain and it gives the water inside. You need a hood for this topic. I think you need to solve the workaround in a short time because the brain cannot breathe now. There is no atmospheric pressure and no air circulation required for cooling. Black plastic pressure sensor, like a button in the middle of the brain. [/ QUOTE]
brain car brain is as below picture. I can't see any blackheads in this brain, I wait for these rains to rest. I'll cover it after that.
but it is necessary to find a good solution.
08.05.2020 18:36 # 5
madblueblacksea
Yes, the structure of your ECU is different from mine
08.05.2020 18:36 # 6
popeyes
Hello friends, I do not know if it would be good to write something again on the subject 2 years later, but I think there are many things that need to be clarified on this subject. I frequently received phone and message from people who entered the site and read the subject. I have been away from the forum for a long time but it has been long enough to specialize in this subject. I sold 206 but I still have a love. By the way, I got 206 for my 2 friends. If we come to the very essence of the subject, we thought that the brain was malfunctioning, but I thought it was the rainwater because it came to the rain and cold weather, but after a long effort, there was a crack in the wires inside the sockets that entered the brain. I frequently encountered malfunction due to the contraction of the wires in the cold weather. By measuring with the voltmeter, I detected the wires of the temperature sensor (green sensor) in the holes where it joins in the sockets. By pushing copper cable through these holes (I did not do anything like soldering etc.), I ensured that the current and information were properly transmitted. so I solved my problem myself. and I learned that the brain malfunctions, but when it is turned off and on, it does not recover once it disconnects the battery. If it is defective, it is defective. Let's take a look at what I have done so far. I have replaced 2 original and 1 temperature sensor. (150 TL) 2- I changed 1 testmostat. (100 TL) 3- I replaced the chassis cables. (50 TL) 4- I installed thick copper cables to reinforce the chassis cables. (25 TL) 5- I brought the brain from France. (100 €) It was understood that there was no malfunction because it gave the old error. 6- I replaced the engine water expansion cap (20 TL) 7- I replaced the heat sensor sockets (2 socket plugs installed on the heat sensor) from Istanbul. (20 TL) 8- I paid 2 times for fault detection in the service (they could not find it) 100 TL9- I removed the front bumper and overhauled the entire fan installation. I took the fan resistance zero and put it on myself (50 TL) 10- I changed the fan switches (step switches) (50 TL) 11- I changed the radiator. (250 TL) 12- Software immo cracking was done to the newly received brain. master fee (100 TL) I paid a fee of 250 TL as a master fee for these procedures. It cost a figure of 1365 TL in total. I could sell that car that way too, but my conscience didn't give a hand because the person I sold was going to get too busy. I detected its malfunction. I used the tool for 5 months without any fault and sold it after making sure that it would not fail. Let the person see the good.
08.05.2020 18:36 # 7
CVT
[QUOTE = popeyes] Friends Hello, I do not know if it would be good to write something on the subject again 2 years later, but I think there are many things that need to be clarified on this subject. I frequently received phone and message from people who entered the site and read the subject. I have been away from the forum for a long time but it has been long enough to specialize in this subject. I sold 206 but I still have a love. By the way, I got 206 for my 2 friends. If we come to the very essence of the subject, we thought that the brain was malfunctioning, but I thought it was the rainwater because it came to the rain and cold weather, but after a long effort, there was a crack in the wires inside the sockets that entered the brain. I frequently encountered malfunction due to the contraction of the wires in the cold weather. By measuring with the voltmeter, I detected the wires of the temperature sensor (green sensor) in the holes where it joins in the sockets. By pushing copper cable through these holes (I did not do anything like soldering etc.), I ensured that the current and information were properly transmitted. so I solved my problem myself. and I learned that the brain malfunctions, but when it is turned off and on, it does not recover once it disconnects the battery. If it is defective, it is defective. Let's take a look at what I have done so far. I have replaced 2 original and 1 temperature sensor. (150 TL) 2- I changed 1 testmostat. (100 TL) 3- I replaced the chassis cables. (50 TL) 4- I installed thick copper cables to reinforce the chassis cables. (25 TL) 5- I brought the brain from France. (100 €) It was understood that there was no malfunction because it gave the old error. 6- I replaced the engine water expansion cap (20 TL) 7- I replaced the heat sensor sockets (2 socket plugs installed on the heat sensor) from Istanbul. (20 TL) 8- I paid 2 times for fault detection in the service (they could not find it) 100 TL9- I removed the front bumper and overhauled the entire fan installation. I took the fan resistance zero and put it on myself (50 TL) 10- I changed the fan switches (step switches) (50 TL) 11- I changed the radiator. (250 TL) 12- Software immo cracking was done to the newly received brain. master fee (100 TL) I paid a fee of 250 TL as a master fee for these procedures. It cost a figure of 1365 TL in total. I could sell that car that way too, but my conscience didn't give a hand because the person I sold was going to get too busy. I detected its malfunction. I used the tool for 5 months without any fault and sold it after making sure that it would not fail. I would like to mention that I am happy to end a matter here. I am still here I love peugeotturkey !!!! [/ QUOTE] Get halal
08.05.2020 18:36 # 8
omerr
Good job
08.05.2020 18:36 # 9
Gokcesel
Thanks can come out to someone who needs it for information. I wish health to your efforts, even if everyone thinks like you, sells the vehicle.
08.05.2020 18:36 # 10
Gokhanca
Good evening, teacher, I have a similar problem,
I took my car to all the masters, including the brainer, and I really spent a lot of money, it was not resolved. Can you help me, please?
At first, I lost the key of my car and I did not even try to run it with a spare key. It did not work. Then, while he was cruising, he stopped and went to the brainwheel with the hammer and said that the problem was in the brain and I had it done. Then the same problem happened again went with the tractor and they replaced the engine fuse box. I had the problem again, they said that it was a short circuit in the vehicle and they said we did it again. I am having the same problem. There is a sound like a snap in the fuse box inside. What can I do? Help me SleepySleepy
08.05.2020 18:36 # 11
Alicilik
Get well soon. Pejo is always a master job.
Is the problem in the sockets or where does the socket fit into the brain? If there are problems with the sockets, I can help you change.
08.05.2020 18:36 # 12
popeyes
unfortunately, seeing these problems is not solved by just trying something.
Let me tell you a few events that will cause this situation,
* Heat guard
* Fan resistance
* Crack in the brain sockets
* There is a chassis in the vehicle
* brain malfunction
* I have a lot to count like this.
I can help you a little bit, call me if you want
08.05.2020 18:36 # 13
Selcuk55
If you buy the cover of the brain, your problem will be resolved.
08.05.2020 18:36 # 14
Gokhanca
Thanks teacher, I will try ..
08.05.2020 18:36 # 15
[QUOTE = Gokhanca] teacher good evening I have a similar problem,
Get well, my brother in Ankara, there is a young electric-electronic master who is only interested in peugeot. as mass peugeot. your problem is probably a situation such as disconnection or oxidation in one or more of the electric cables. you get an idea from nothing.
08.05.2020 18:36 # 16
Gokhanca
thanks for your help guys
08.05.2020 18:36 # 17
406SVBVA
Hello Brother
I'm having the same problem right now. They said the contact thermic did not change, the electric box did not say, the sensor said, did not change :(
Did you solve your problem?
08.05.2020 18:36 # 18
Gurcan
I have the same problem in me, I did the same, but it still doesn't work in the rain, or rather, it works if it wants it, but generally it doesn't work in the rain
08.05.2020 18:36 # 19
popeyes
Hello, there is one more topic I wrote about the breakdown. Let me summarize the situation as follows.
If my socket cables are cracked and you read correction continue messages, you will find them, if the subject you are writing continues with the same problems and your vehicle is 206, I think it may be due to a small crack in the brain that is very likely to have a brain malfunction. For this, there is an expert company in ankara / shakmaz, the guys are making direct point shots.
08.05.2020 18:36 # 20
serknrn
I would like your urgent help
I have a 2004 partner 1.9 air-conditioned diesel vehicle.
Last morning, I will start the car, it does not work. It has battery, electricity, fuel, oil, water but it does not work.
The other master key has a chip, it may be broken, if you turn the key when it breaks, it doesn't send a signal to the brain, naturally the engine can't get the data needed to draw fuel and it won't work.
The same master may have gone in the brain, 600 lira brain, 300 tl key can hold about prices, he said.
I'm waiting for your ideas, my car is waiting at the door, I can't see my strength.
Page : / 2
